I have run up the 8400 suit 6.5, all services running can create message service and vmail is registered on oxe. When I try to install the rpm TTS files it fails due to not finding dependency files, two lib files? Any ideas would be appreciated.
8400 ICS TTS Installation fail due to dependencies not found
Re: 8400 ICS TTS Installation fail due to dependencies not f
how are you doing the install?
Did you install RH with the boot cd, right?
russty
Thanks for your reply, I tried again but used --nodeps and it worked fine. Cheers Russty
Hi russty,
Did you install the TTS file with the "--force" parameter ?
The commands for the installation of TTS file should be :
- TTS engine :
- TTS Language :
- TTS engine :
rpm -ivh <file of TTS engine>.rpm --nodepsCode: Select all
rpm -ivh <file of TTS language>.rpm --forceSorry for my english ....
russty
Thanks for your reply, I did use force as well as nodeps and it worked fine. Cheers again Russty
