Hello to all,
a customer wishes to work with ALU SoftPanel client under Linux OS and Firefox.
Is this able to do?
RainerO
SoftPanel client working with Firefox / Linux ?
krzysioD
Re: SoftPanel client working with Firefox / Linux ?
Standard ALU client on 32" LCD is linux based, and it was from the very beginning.
So: Yes.
As for EDIT: it works for me for current version.
So: Yes.
RainerO
Thank you, krzysioD.krzysioD wrote:Standard ALU client on 32" LCD is linux based, and it was from the very beginning.
So: Yes.
I saw an older topic of you regarding problems with Sychro Server / manual synchronisation with StartssbdMaint.bat.
Actually have the same problem (Many lines with message "CALL Do_Up_Acapi").
Did you solve the problem? I have no reaction when I type resync P.
RainerO
datareven
I just had the same problem regarding RSISynchroServer. Restarting the OXE and OTPE had no effect.
After starting and stopping RSISynchroServer application via SCI, and running StartssbdMaint.bat several times I still had the same problem.
The solutinon for me was to stop the RSISynchroServer application via SCI, and modify the log on the RSISynchroServer like it is written in the tg0060-ed.01 genesys compact edition trou_en.pdf (this file you can download on the AL BPW).
TEXT: 12.2 No log when running StartSsbdMaint.bat
Problem description:
No log are produced or logs stops after few lines when running StartSsbdMaint.bat.
Possible reason(s):
“Console” option in not selected with log level set to DEBUG in RSISynchroServer log wizard and mark all boxes for Plain Text File and Console, Standard box for Network.
Then run the StartSsbdMaint.bat again and hopefully the state is READY. In my case I had a voiceguide missmatch in the syncrorange. After resync G and resync P I started the RSISynchroServer application via SCI and the system are working fine.
Possible reason(s):
