Beggining with crons
20deoctubre
Post by 20deoctubre »
I'm new to OXE. The first thing that I have noted in here is the possibility to program crons which is a very interesting task.
I'm trying to write a simple cron just to make a new directory:
1.- > crontab -e (it opens the cron editor)
2. > 18 17 * * * mkdir usr4/BACKUP/test
The cron isn't working, the folder is not being created. I suspect that this is something related to permissions, but I'm not sure.
Am I doing something wrong?
A difference I have noted between OXE and Linux (Ubuntu) is that when you are programing a cron on Ubuntu you have to specify a user.
Well thanks for your time
Eliott
Re: Beggining with crons
Post by Eliott »
First must be run as root
Leading slash missing
mkdir /usr4/BACKUP/test
