INCOMING CALL FILTERING
If there are features that receive over 1,000 votes, AlcatelUnleashed will contact AlcatelLucent as a conglomerat, and will try to get the feature(s) implemented in future releases of the OXE or OXO
Is a call filtering option a must-have in the OXE ?
Yes, I want to be able to easily filter any incoming DID to any internal extension
5
83%
No, I don't really need this function
1
17%
Total votes: 6
Many times I read topics where someone is looking to filter incoming calls.
Let's start with this feature as a first test. If we get over 1,000 votes, AlcatelUnleashed will represent you as a conglomerate and will try to have this done in one of the next releases.
Re: INCOMING CALL FILTERING
We say about feature different from "caller / called filtering" present in OXE?
Yes, an easy feature called "incoming call filtering" that the admin can do on a PBX level for example.
Does anyone have more info about this in R11:
439663 PER 1-142772960: incoming call filtering enhancement. Implemented "Calling numbers are routed towards an unique filtering number (via DDI translator), and if the call is authorized, it will be routed towards the initial called number via a second DDI translation. Specifc and non-funded => will not be delivered and supported by ALE"
In my understanding this solves the request...
Return to “OT/OXE/OXO FEATURES REQUESTS”
