Alcatel A4400 R32714.3 Problems with Clip
mirzem
Post by mirzem »
Hi Guys.
My Telephone Provider says:
CLIP is on. but to see our calling number extern our calling Number Fromat sholud not be UNKNOWN
Can somebody help me to find the correct configuration?
Thanks a lot.
Greetz mirzem from Germany
Re: Alcatel A4400 R32714.3 Problems with Clip
Hi!
Do you have CLIDSP daughterboard on your APA or NDDI board?
As I understand you have problem with outgoing call and numbering plan.
If I right:
Trunk groups/ PTT trunk group/ NPD selector - you can find NPD used for outgoing calls.
Translator/ Ext. numbering plan/ Numbering plan description - for NPD used in trunk group you can change Calling numb.plan (NPI/TON) - f.e. insted of ISDN/Unknown select ISDN/National.
Return to “System”
