Do anyone know what the "-Inf" means? Has anyone successfully used the -ER SFP+ on either OS6850E or OS10K? I've opened a case with ALU support and am waiting for someone to get back to me.
Below is some captures from testing on an OS6850E, running 6.4.4.508.R01 with SFP-10G-ER in 1/49 and SFP-10G-LR in 1/50
thank you for any help,
John
RCA-John01>> show interfaces transceiver
Slot/ Thres- Temp Voltage Current Output Input
Port hold (C) (V) (mA) (dBm) (dBm)
1/49 Actual 22.0 3.335 0.000(AL) -Inf(AL) 0.000
A-High 75.0 3.630 100.000 7.000 2.000
W-High 70.0 3.465 95.000 4.000 -1.000
W-Low 0.0 3.135 55.000 -4.701 -15.800
A-Low -5.0 2.970 50.000 -8.700 -19.788
1/50 Actual 33.0 3.307 37.858 -1.362 0.000
A-High 78.0 3.700 85.000 2.000 2.500
W-High 73.0 3.600 80.000 1.000 2.000
W-Low -8.0 3.000 20.000 -7.001 -18.013
A-Low -13.0 2.900 15.000 -8.000 -20.000
WL - Exceeds warning low limit
WH - Exceeds warning high limit
AL - Exceeds alarm low limit
AH - Exceeds alarm high limit
RCA-John01>> show ni
Module in slot 1
Model Name: OS6850E-P48X,
Description: 48 G POE 2 10G,
Current Switch mode : OS6850E,
Saved Switch mode : OS6850E,
Part Number: 902933-90,
Hardware Revision: 08,
Serial Number: M3583149,
Manufacture Date: AUG 27 2011,
Firmware Version: ,
Admin Status: POWER ON,
Operational Status: UP,
Power Consumption: 0,
Power Control Checksum: 0xaf52,
CPU Model Type : Motorola MPC8248,
MAC Address: e8:e7:32:16:a9:2a,
ASIC - Physical 1: BCM56514_A0,
ASIC - Physical 2: BCM56514_A0,
FPGA - Physical 1: 00010/00,
UBOOT Version : 6.4.4.213.R01,
UBOOT-miniboot Version : 6.4.4.213.R01,
POE SW Version : n/a
GBIC 49
Manufacturer Name: FINISAR CORP. ,
Part Number: FTLX1671D3BCL ,
Hardware Revision: A ,
Serial Number: UKB0AA0 ,
Manufacture Date: 110316 ,
Laser Wave Length: 1550nm,
GBIC 50
Part Number: FTLX1471D3BCL ,
Serial Number: UKG0BP1 ,
Manufacture Date: 110415 ,
Laser Wave Length: 1310nm,
