SIP TRUNK TO ISDN TRUNK
luis.molinas
Post by luis.molinas »
I have a next task to do, if anyone have an idea of how to do it, i'll thank you!!
i have deployed an OXER9.1 and a SIPServer8.1 both of them are linked by sip trunk.
In the OXE i have installed an E1 for oubound calls. I need to know how to configure the OXE to make the endpoints from SIPServer,where they are making the oubound call, are routed to the E1 of the OXE.
Datas:
OXER9.1
prefix to access to public network : "0" (ARS Prof.Trg Grp Seizure)
E1 TG : 20 (isdn all countries)
SIPServer TG: 63 (ABC-F, T2 specification = SIP)
Ext GW: 1
Genesys SIPServer
Switches: Alcatel_OXE
DN type = Trunk (Tunk to OXE)
Anex * Prefix = 021
* Contact = oxe ip
Best Regras
Re: SIP TRUNK TO ISDN TRUNK
Luis,
I would suggest to go in the BPWS and download the IWR for IPC.
THere is a configuration example on how OXE is connected to a SIP server (incoming), and how OXE routes incoming SIP calls to T1.
Return to “Trunk Groups”
