From CBRMA box To PC Hiperterminal connection
shirantha
Post by shirantha »
Dear All,
Please update me how to prepare Comport cable to use OXE CBRMA box connetion with PC com port
( 24 pot Jack male /CBRMA box AO port ----- 9 pin femal jack for my PC )
Shirantha
Re: From CBRMA box To PC Hiperterminal connection
Hi ,
Are you trying to make the cable yourself ?
Or you want the references of the needed cable ?
shirantha
Post by shirantha »
Dear,
I ant to know how to make comporl cable ( pin cannection ,From 24 pin jack to 9 pin jak)
Shirantha
Seller_V
Post by Seller_V »
I suppose you mean CBRMA console cable? Nullmodem cable is needed. I usually make it myself.
Pins:
DB9 DB25
1 20
2 2
3 3
4 6+8
5 7
6 20
7 5
8 4
ABDY
Post by ABDY »
Dear all,
What is the part number of that CBRMA console cable??
Thanks a lot in advance!
mokhtar14
Post by mokhtar14 »
dear all
please what's the refrence of this type of cable .
Thanks a lot in advanced
ACFE OXE R10
alex
Post by alex »
ALcatel does not supply such a cable.
You need to make it yourself or order one with the required pinout(Nullmodem).
See here
Seller_V wrote: ↑24 Jul 2012 02:52 I suppose you mean CBRMA console cable? Nullmodem cable is needed. I usually make it myself.
Pins:
DB9 DB25
1 20
2 2
3 3
4 6+8
5 7
6 20
7 5
8 4
I've got mine for decades working fine just with this connections:
DB9 DB25
2 2
3 3
5 7
the cabel is cable cross v24 3ba58091aaaa but you need the null modem db25-db9
i got http error when i try to upload a pic of my cable
check your email
