specific number calling outbound release.
thkim81
Post by thkim81 »
hi~
When I calling 011-XXXX-XXXX , calling was release.
then I check the t3 log.
Traces Analyser activated
mtracer started ...
(303514:000001) MTRACER host (10.8.246.12, hdgf_a), version: R10.0-j1.410-38-c-kr-c0
(303514:000001) MTRACER num: 016, time: 2012/07/13 04:59:16, loss: 0%
| (303593:000005) 1463: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 61 desti: 0 source: 15 cryst: 2 cpl: 26 us: 8 term: 1 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 70 e6
| IE:[18] CHANNEL (l=3) a9 83 9f -> T2 : B channel 31 exclusive
| IE:[6c] CALLING_NUMBER (l=12) -> 01 81 Num : 0808581133
| IE:[70] CALLED_NUMBER (l=12) -> 81 Num : 01192087499
| IE:[7d] HLC (l=2) 91 81
| [a1] Sending complete
| (303595:000007) Concatenated-Physical-Event :
| long: 27 desti: 0 source: 0 cryst: 2 cpl: 26 us: 0 term: 1 type a5
| tei: 0 >>>> message received : CALL PROC (02) Call ref : f0 e6
| IE:[1e] PROGRESS_ID (l=2) 82 88
| (303602:000008) Concatenated-Physical-Event :
| long: 64 desti: 0 source: 0 cryst: 2 cpl: 26 us: 0 term: 1 type a5
| tei: 0 >>>> message received : ALERT (01) Call ref : f0 e6
| IE:[28] DISPLAY (l=40) `In-Band Info Avail.
listen... `
| (303652:000010) 1463: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 26 us: 8 term: 1 type a5
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 9a 4c
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
| (303653:000011) Concatenated-Physical-Event :
| long: 67 desti: 0 source: 0 cryst: 2 cpl: 26 us: 0 term: 1 type a5
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 1a 4c
| IE:[08] CAUSE (l=2) 80 90 -> [90] NORMAL CALL CLEARING
| IE:[28] DISPLAY (l=40) `Call Released.
| IE:[34] SIGNAL (l=1) 03
| (303653:000013) 1463: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 2 cpl: 26 us: 8 term: 1 type a5
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 9a 4c
| IE:[08] CAUSE (l=3) 81 e3 34 -> [e3]
| INFORMATION ELEMENT NON-EXISTENT OR NOT IMPLEMENTED
| (303655:000014) 1463: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 26 desti: 0 source: 15 cryst: 2 cpl: 26 us: 8 term: 1 type a5
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 70 e5
| IE:[1e] PROGRESS_ID (l=2) 81 88
| (303657:000015) Concatenated-Physical-Event :
| long: 47 desti: 0 source: 0 cryst: 2 cpl: 26 us: 0 term: 1 type a5
| tei: 0 >>>> message received : RELEASE [4d] Call ref : f0 e5
| IE:[28] DISPLAY (l=20) `Call Released. `
| IE:[34] SIGNAL (l=1) 08
| (303657:000016) 1463: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 70 e5
when I calling this part
listen...
I heard busy tone and call is disconnect.
I change the configure below :
Listen to guide on DISCONNECT + false -> true
but call was release.
who knows about this problem ?
Return to “Trunk Groups”
