Q931 Signal variant set to ISDN breaks prefix plan?
DS_Eire
Post by DS_Eire »
I have the following trunk and network parameters on my OXE
Network Routing Table has - Protocol Type + ABC_F
Trunk Type is:
Trunk Group Type + T2
T2 Specification + SIP
Q931 Signal variant + ISDN all countries
My trunk type was previously set with "Q931 Signal variant + ABC-F", when it was I was able to go into Translator --> Prefix Plan and create a prefix using this trunk ( Node Number/ABC-F Trunk Group )
I then had to change the "Q931 Signal variant+ ISDN all countries" but after I did I was no longer able to create a prefix plan to use this trunk.
It works when the trunk value for Q931 Signal variant is ABC-F but not ISDN all countries.
Is there something i can do to allow me create a prefix for this trunk but still allow the trunk be set to ISDN all countries
Return to “Trunk Groups”
