Oxo- clock running fast.
davidrunciman
Hello, i've been for some information about chagning time and date on the oxo (because time on the users sets seems to be running 12 minutes fast ) but couldn't find anything. Any help would be appreciated.
- mustafa.ahmad
Re: Oxo- clock running fast.
u can change it from the operator set,
or u can change it from the OMC, system miscellaneous
davidrunciman
Thanks for the quick reply, i have been looking in system miscellaneous but couldn't find anything about changing time.
Hope you can help me a little bit more.
- mustafa.ahmad
when u are connected to the system, in the system miscellaneous, there is an option to set PCX time...
louh
Hi All sir,
It's possible to modify system's parameter so the sysetm will adjust the clock itself, and we don't need to adjust clock all the time?
Thanks a lot
Thanks a lot
davidrunciman
I believe it can't be done, there is no such thing as sync the oxo with another clock (such a ntp server), it can only sync with the pstn clock.
- tot3nkopf
NTP server connection is available from R9.0
You can use time update from E1/T1 access if the provider supports it.
