Hybrid link creation Problem
mohamed-eid
Post by mohamed-eid »
Hello Dears,
When I try to create Hybrid Link, to enable users to call pilot directory number, I get "Access Denied".
is there is a missing configuration to enable me to create a Hybrid Link.
enio.eltz
Re: Hybrid link creation Problem
Post by enio.eltz »
Check this file.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
jpissot
Post by jpissot »
Have you the license to Hybrid link?
enio.eltz
Post by enio.eltz »
Yes, it can be his problem. I did a test with CCD in lab, but I used free licenses during 30 days.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
There is no license associated to CCD loopback hybrid link, only paramao value needs to be adjusted (this was debated several times - so search could have been your friend), either directly in PBx or in Actis (preferably in Actis in order to be ticked also in future upgrades). You can do that with cfgUpdate utility. A reboot or double bascul is needed.
viewtopic.php?f=277&t=489&hilit=ccd+loop
vish443
Post by vish443 »
how we check the in license?
how many we create hybrid link as well as abcf t2 link in oxe???
Return to “Inter-Node Links”
