OS6450-P10 switch and Cisco Switch not seeing each other
ddemers
Post by ddemers »
Hello, I am very new to OmniSwitch configuration but I believe I have it correct...believe...
I want to have port 1/8 in VLAN 408 and see port fa0/1 on the Cisco which I have both had it as a trunk and an access port as 408.
6450 Config as Follows
! Stack Manager :
! Chassis :
system daylight savings time disable
! Configuration:
! VLAN :
vlan 1 enable name "VLAN 1"
vlan 408 enable name "VLAN 408"
vlan 408 port default 1/8
! VLAN SL:
! IP :
ip service all
! IPMS :
! AAA :
! System service :
swlog console level info
Cisco 2950 as Follows
interface FastEthernet0/1
switchport trunk allowed vlan 408
switchport mode trunk
Cisco Second Config
switchport access vlan 408
switchport mode access
THEY dont see each other however the link lights are blinking constantly so something is happening.
I am at the point I just want to see something in arp...they dont have any arp additions in either of the devices.
benny
Re: OS6450-P10 switch and Cisco Switch not seeing each other
Post by benny »
You have asked the OmniSwitch to use the VLAN 408 as native vlan, not as a dot1q connection.
-> vlan 1 port default 1/8
-> vlan 408 802.1q 1/8 "here you could provide a comment"
Return to “OmniSwitch 6400”
