Captive Portal on 6850
Mi0
Post by Mi0 »
Dear all,
I'm trying to design a network with Captive Portal, but my customer requested to use only CP peer network. Is it possible to configure only one CP peer network and redirect all CP authentication request to one switch? Or do I have to configure CP on each switch. Documentation does not say anything about this possibilities.
I was thinking to configure a new IP address for the CP on each switch: 802.1X captive-portal address 10.124.0.1, but I'm not sure if it will work or not.
Milan
one6f
Re: Captive Portal on 6850
Post by one6f »
Maybe that helps.
This command changes only the default Alcatel ip 10.123.0.1 to 10.124.0.1 in case that you are already use 10.123.0.1 in your config.
