GA3 board REG NOT INTIALIZE ON PCS
lakme231
Post by lakme231 »
The GA3 board does not come in service on the pcs. It comes in service on the main CS but the status shows "REG NOT INIT" and all other boards come in service. I performed the incvisu and I get the following error "Config error or Loss of IP connection: 4,(14,3),10.54.88.5,00:80:9f:9d:56:d6." Also when the GA3 BOARD is booting up, it also shows " HWaddr of eth0 - 00:80:9F:9D:56:D6 - is still in use by bond0. Set the HWaddr of eth0 to a different address to avoid con" this line. does anyone know how to fix this. Any feedback is greatly appreciated.
GA3 board configuration
Node Number (reserved) : 3 ³
³ Shelf Address : 14 ³
³ Board Address : 1 ³
³ ³
³ Interface Type + GA3 ³
³ Virtual board + NO ³
³ Serial number : -------------- ³
³ Usage State + Idle ³
³ Operational State + Disabled ³
³ Main/Standby State + Main (Master) ³
³ Number Of Sets Connected : 0 ³
³ Country + Default ³
³ Incidents Teleservice + YES ³
³ Daughter Board + ARMADA ³
³ No. of Compressors for IP Devices : 60 ³
³ N part conferences configuration + No conference ³
³ N part conference type + Add-on
³ Shelf - Board Address : 14-1 ³
³ ³
³
³ Board IP Address : 10.54.88.4 ³
³ IP NetMask : 255.255.255.0 ³
³ Default Gateway IP Address : 10.54.88.1 ³
³ IP Quality of service : 14 ³
³ Cryptographic box address : --------------------------------------- ³
³ Board Ethernet Address : 00:80:9F:9D:56:D6 ³
³ Interworking with Gatekeeper + NO ³
³ Gatekeeper ID : -1 ³
³ Numb. of sig. channels IP Phones : 0 ³
³ Numb. of sig. channels inter-ACT : 0 ³
³ IP Domain Number : 555 ³
³ E164 Number List Index : -1 ³
³ Ethernet Configuration + Forced 100 Mbps Full duplex ³
³ Gateway H323 name : -------------------------------- ³
³ ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
Thanks in advance.
Some of thing I tried already:
- rebooting the GA
- It has the LAN connectivity to the switch
- erasing the mac by shitf+"" and again rebooting it so that it picks up.
Return to “Boards”
