Does anybody knows how to create alarms script, so that it can be filtered to send an email via 4760.
Thanks in advance
Creating script for oxe alarms
Zero
Re: Creating script for oxe alarms
Hi ksc609,
If you find this helpful, please try the procedures below.
How to Configure Alarm Filter
A. To create a filter thru mail sending
Procedure:
1. Click, Alarms Application
2. Go to Menu Bar and select Preferences
3. Choose, Alarms
4. Click, Alarm filters
5. Then, Alarm Filters window appears. Key-in, name for the alarm filters. For example, Major & Critical Alarms
6. Click, Add button
7. Create filters according to severity
8. Click, (+) plus button to add another severity filter
9. Select, Or to filter either the first item or the second item
10. Choose appropriate severity level
11. Select, E-Mail Addresses tab
12. Key-in, email addresses that will received the alarm notification
13. Click, Add button
B. To define the mail server
Procedure:
1. Click, Directory Application
2. Select, System tab
3. Expand nmc and select server name (VOIP)
4. Select, Export parameters tab
5. For Mail Server parameter, enter mail server name including the SMTP TCP port (:25). For example, mailservername:25
6. For Name of the mail sender parameter, enter valid email address. For example, mymail@mailservername.com.ph
7. Click, Check button to apply changes
Thanks,
Zero
Procedure:
3. Choose, Alarms
Procedure:
Thanks,
Zero
ksc609
Thanks.....but in this process all the alarms will be sent via e-mail & I required few particular alarms only to be e-mailed.
Zero
Hi ksc609,
Notwithstanding, the procedure is based on sending alarms by filtering the severity level and not in particular to notifying specific item of the alarm.
Thank you.
Kind regards,
Zero
In reference to the provided procedures, A.7 to A.10 describes the filtering key wherein any matching criteria will be notified not unless all filtering keys will be set then definitely all alarms matching the criteria will be received.ksc609 wrote:... all the alarms will be sent...
Thank you.
Kind regards,
Zero
andrewm
In relation to A. To create a filter thru mail sending, I have created an escalation via email, hos do I now locate that entry and edit, change / delete entry?
In relation to B. To define the mail server, in my 8770 I do not have option for Directory Application, I have Network, Reporting and Setup. Am I missing something or looking in wrong place?
Thanks in advance and very appreciated.
mailserver in 8770 can be configured in setup section.
directory is only visible when directory license available.
regards...
--- back to basics... focus your eyes on the essential things... ---
regards...
