here are the specific commands we think should do the trick
802.1x 1/x supplicant policy authentication fail captive-portalThe Radius logs tells me "Network Policy Server denied access to a user."
Wireshark tells me that the Radius server answers with code 3 "Access-Reject"
Here is the entire configuration:
Welcome to the Alcatel-Lucent OmniSwitch 6000
Software Version 6.4.2.807.R01 GA, August 27, 2009.
Copyright(c), 1994-2009 Alcatel-Lucent. All Rights reserved.
OmniSwitch(TM) is a trademark of Alcatel-Lucent registered
in the United States Patent and Trademark Office.
-> show configuration snapshot
! Stack Manager :
! Chassis :
system name OS6850-<placering>
system timezone +01:00
! Configuration:
! VLAN :
vlan 1 enable name "VLAN 1"
vlan 20 enable name "VLAN 20"
vlan 20 port default 1/11
vlan 20 port default 1/12
vlan 20 port default 1/13
vlan 20 port default 1/14
vlan 20 port default 1/15
vlan 20 port default 1/16
vlan 20 port default 1/17
vlan 20 port default 1/18
vlan 20 port default 1/19
vlan 20 port default 1/20
vlan 20 port default 1/21
vlan 20 port default 1/22
vlan 20 port default 1/23
vlan 20 port default 1/24
vlan 20 port default 1/37
vlan 20 port default 1/38
vlan 20 port default 1/39
vlan 20 port default 1/40
vlan 20 port default 1/41
vlan 20 port default 1/42
vlan 20 port default 1/43
vlan 20 port default 1/44
vlan 20 port default 1/45
vlan 20 port default 1/46
vlan 20 port default 1/47
vlan 30 enable name "Visitors"
vlan 30 port default 1/25
vlan 30 port default 1/26
vlan 30 port default 1/27
vlan 30 port default 1/28
vlan 30 port default 1/29
vlan 30 port default 1/30
vlan 30 port default 1/31
vlan 30 port default 1/32
vlan 30 port default 1/33
vlan 30 port default 1/34
vlan 30 port default 1/35
vlan 30 port default 1/36
vlan 61 port default 1/9
vlan 61 port default 1/10
vlan 99 enable name "radius"
vlan 99 port default 1/5
vlan 99 port default 1/6
vlan 100 enable name "SERVER"
vlan 100 port default 1/3
vlan 100 port default 1/4
vlan 999 enable name "Management"
vlan 999 port default 1/1
vlan 999 port default 1/2
vlan 999 port default 1/49
vlan port mobile 1/13
vlan port mobile 1/14
vlan port mobile 1/15
vlan port mobile 1/16
vlan port mobile 1/17
vlan port mobile 1/18
vlan port mobile 1/19
vlan port mobile 1/20
vlan port mobile 1/21
vlan port mobile 1/22
vlan port mobile 1/23
vlan port mobile 1/24
vlan port mobile 1/25
vlan port 1/25 802.1x enable
vlan port mobile 1/26
vlan port 1/26 802.1x enable
vlan port mobile 1/27
vlan port 1/27 802.1x enable
vlan port mobile 1/28
vlan port 1/28 802.1x enable
vlan port mobile 1/29
vlan port 1/29 802.1x enable
vlan port mobile 1/30
vlan port 1/30 802.1x enable
vlan port mobile 1/31
vlan port 1/31 802.1x enable
vlan port mobile 1/32
vlan port 1/32 802.1x enable
vlan port mobile 1/33
vlan port 1/33 802.1x enable
vlan port mobile 1/34
vlan port 1/34 802.1x enable
vlan port mobile 1/35
vlan port 1/35 802.1x enable
vlan port mobile 1/36
vlan port 1/36 802.1x enable
vlan port mobile 1/37
vlan port 1/37 802.1x enable
vlan port mobile 1/38
vlan port 1/38 802.1x enable
vlan port mobile 1/39
vlan port 1/39 802.1x enable
vlan port mobile 1/40
vlan port 1/40 802.1x enable
vlan port mobile 1/41
vlan port 1/41 802.1x enable
vlan port mobile 1/42
vlan port 1/42 802.1x enable
vlan port mobile 1/43
vlan port 1/43 802.1x enable
vlan port mobile 1/44
vlan port 1/44 802.1x enable
vlan port mobile 1/45
vlan port 1/45 802.1x enable
vlan port mobile 1/46
vlan port 1/46 802.1x enable
vlan port mobile 1/47
vlan port 1/47 802.1x enable
! VLAN SL:
! IP :
ip service all
ip interface "Management" address 192.168.248.60 mask 255.255.255.0 vlan 999 no
forward ifindex 1
ip interface "radius" address 192.168.249.60 mask 255.255.255.0 vlan 99 no forward ifindex 6
! IPX :
! IPMS :
! AAA :
aaa radius-server "radius" host 10.0.0.150 key a4ac44fb47c67404 retransmit 3 timeout 2 auth-port 1812 acct-port 1813
aaa authentication 802.1x radius
aaa radius agent preferred 192.168.249.60
! PARTM :
! AVLAN :
aaa avlan default dhcp 10.10.10.130
! 802.1x :
802.1x 1/25 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/25 captive-portal session-limit 12 retry-count 3
802.1x 1/25 supp-polling retry 2
802.1x 1/25 supplicant policy authentication pass block fail captive-portal
802.1x 1/25 non-supplicant policy captive-portal
802.1x 1/25 captive-portal policy authentication pass block fail block
802.1x 1/26 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/26 captive-portal session-limit 12 retry-count 3
802.1x 1/26 supp-polling retry 2
802.1x 1/26 supplicant policy authentication pass block fail captive-portal
802.1x 1/26 non-supplicant policy captive-portal
802.1x 1/26 captive-portal policy authentication pass block fail block
802.1x 1/27 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/27 captive-portal session-limit 12 retry-count 3
802.1x 1/27 supp-polling retry 2
802.1x 1/27 supplicant policy authentication pass block fail captive-portal
802.1x 1/27 non-supplicant policy captive-portal
802.1x 1/27 captive-portal policy authentication pass default-vlan fail block
802.1x 1/28 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/28 captive-portal session-limit 12 retry-count 3
802.1x 1/28 supp-polling retry 2
802.1x 1/28 supplicant policy authentication pass block fail captive-portal
802.1x 1/28 non-supplicant policy captive-portal
802.1x 1/28 captive-portal policy authentication pass default-vlan fail block
802.1x 1/29 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/29 captive-portal session-limit 12 retry-count 3
802.1x 1/29 supp-polling retry 2
802.1x 1/29 supplicant policy authentication pass block fail captive-portal
802.1x 1/29 non-supplicant policy block
802.1x 1/29 captive-portal policy authentication pass default-vlan fail block
802.1x 1/30 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/30 captive-portal session-limit 12 retry-count 3
802.1x 1/30 supp-polling retry 2
802.1x 1/30 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/30 non-supplicant policy block
802.1x 1/30 captive-portal policy authentication pass default-vlan fail block
802.1x 1/31 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/31 captive-portal session-limit 12 retry-count 3
802.1x 1/31 supp-polling retry 2
802.1x 1/31 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/31 non-supplicant policy block
802.1x 1/31 captive-portal policy authentication pass default-vlan fail block
802.1x 1/32 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/32 captive-portal session-limit 12 retry-count 3
802.1x 1/32 supp-polling retry 2
802.1x 1/32 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/32 non-supplicant policy block
802.1x 1/32 captive-portal policy authentication pass default-vlan fail block
802.1x 1/33 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/33 captive-portal session-limit 12 retry-count 3
802.1x 1/33 supp-polling retry 2
802.1x 1/33 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/33 non-supplicant policy block
802.1x 1/33 captive-portal policy authentication pass default-vlan fail block
802.1x 1/34 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/34 captive-portal session-limit 12 retry-count 3
802.1x 1/34 supp-polling retry 2
802.1x 1/34 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/34 non-supplicant policy block
802.1x 1/34 captive-portal policy authentication pass default-vlan fail block
802.1x 1/35 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/35 captive-portal session-limit 12 retry-count 3
802.1x 1/35 supp-polling retry 2
802.1x 1/35 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/35 non-supplicant policy block
802.1x 1/35 captive-portal policy authentication pass default-vlan fail block
802.1x 1/36 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/36 captive-portal session-limit 12 retry-count 3
802.1x 1/36 supp-polling retry 2
802.1x 1/36 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/36 non-supplicant policy block
802.1x 1/36 captive-portal policy authentication pass default-vlan fail block
802.1x 1/37 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/37 captive-portal session-limit 12 retry-count 3
802.1x 1/37 supp-polling retry 2
802.1x 1/37 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/37 non-supplicant policy captive-portal
802.1x 1/37 captive-portal policy authentication pass default-vlan fail block802.1x 1/38 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/38 captive-portal session-limit 12 retry-count 3
802.1x 1/38 supp-polling retry 2
802.1x 1/38 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/38 non-supplicant policy block
802.1x 1/38 captive-portal policy authentication pass default-vlan fail block
802.1x 1/39 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/39 captive-portal session-limit 12 retry-count 3
802.1x 1/39 supp-polling retry 2
802.1x 1/39 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/39 non-supplicant policy block
802.1x 1/39 captive-portal policy authentication pass default-vlan fail block
802.1x 1/40 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/40 captive-portal session-limit 12 retry-count 3
802.1x 1/40 supp-polling retry 2
802.1x 1/40 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/40 non-supplicant policy block
802.1x 1/40 captive-portal policy authentication pass default-vlan fail block
802.1x 1/41 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/41 captive-portal session-limit 12 retry-count 3
802.1x 1/41 supp-polling retry 2
802.1x 1/41 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/41 non-supplicant policy block
802.1x 1/41 captive-portal policy authentication pass default-vlan fail block
802.1x 1/42 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/42 captive-portal session-limit 12 retry-count 3
802.1x 1/42 supp-polling retry 2
802.1x 1/42 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/42 non-supplicant policy block
802.1x 1/42 captive-portal policy authentication pass default-vlan fail block
802.1x 1/43 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/43 captive-portal session-limit 12 retry-count 3
802.1x 1/43 supp-polling retry 2
802.1x 1/43 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/43 non-supplicant policy block
802.1x 1/43 captive-portal policy authentication pass default-vlan fail block
802.1x 1/44 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/44 captive-portal session-limit 12 retry-count 3
802.1x 1/44 supp-polling retry 2
802.1x 1/44 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/44 non-supplicant policy block
802.1x 1/44 captive-portal policy authentication pass default-vlan fail block
802.1x 1/45 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/45 captive-portal session-limit 12 retry-count 3
802.1x 1/45 supp-polling retry 2
802.1x 1/45 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/45 non-supplicant policy block
802.1x 1/45 captive-portal policy authentication pass default-vlan fail block
802.1x 1/46 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/46 captive-portal session-limit 12 retry-count 3
802.1x 1/46 supp-polling retry 2
802.1x 1/46 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/46 non-supplicant policy block
802.1x 1/46 captive-portal policy authentication pass default-vlan fail block
802.1x 1/47 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/47 captive-portal session-limit 12 retry-count 3
802.1x 1/47 supp-polling retry 2
802.1x 1/47 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/47 non-supplicant policy block
802.1x 1/47 captive-portal policy authentication pass default-vlan fail block
! QOS :
! Policy manager :
! Session manager :
session timeout cli 120
session timeout ftp 30
session timeout http 120
! SNMP :
snmp security no security
snmp community map mode off
snmp community map "SMART-labRO" user "SMART-labRO" on
snmp community map "SMART-labRW" user "SMART-labRW" on
snmp station 192.168.248.1 162 v1 enable
! RIP :
! OSPF :
! BFD-STD :
! ISIS :
! IPv6 :
! IPSec :
! IP multicast :
ip static-route 10.0.0.0/24 gateway 192.168.249.254 metric 1
! RIPng :
! OSPF3 :
! BGP :
! Health monitor :
! Interface :
interfaces 1/1 alias "Trunk_OS9700"
! Udld :
! Netsec :
! Port Mapping :
! Link Aggregate :
! VLAN AGG:
! 802.1Q :
vlan 20 802.1q 1/48 "TAG PORT 1/48 VLAN 20"
vlan 30 802.1q 1/48 "TAG PORT 1/48 VLAN 30"
vlan 61 802.1q 1/48 "TAG PORT 1/48 VLAN 61"
vlan 99 802.1q 1/48 "TAG PORT 1/48 VLAN 99"
vlan 100 802.1q 1/48 "TAG PORT 1/48 VLAN 100"
! Spanning tree :
bridge mode 1x1
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
ip helper avlan only
! Server load balance :
! System service :
swlog console level info
! SSH :
! VRRP :
! Web :
! AMAP :
! LLDP :
! Lan Power :
! NTP :
! RDP :
! VLAN STACKING:
! Ethernet-OAM :
! EFM-OAM :
! E
