TC0521 - Reformatting and reloading the E-MDG NAND FLASH
Here you will find the official Technical Communications from Alcatel.
If you have some to add, contact tincho.rn
Locked
This document provide a procedure which allows to reformat and reload the e-MGD binaries in case of corrupted -MGD NAND Flash.
Keywords:
TC0521 flash gd ga mgd binaries nand
Locked
Return to “OFFICIAL TC's”
