Debug of DB connection on call qualification
joao.carlos
Post by joao.carlos »
Hi everybody,
I'm using GCE 1.0 and the feature of qualification of a call with a Visual IVR Resource Group.
The Visual IVR script asks for a PIN Code, and then makes two databases queries, to get name and VIP status of the cliente.
Based on the VIP status, i want to redirect the call to a specific segment.
I've created the Database Access Point, created the script (3 blocks - Digit Collection, Database Lookup and Database Lookup) and attach data in all of the blocks with each return (PIN_Code, NAME, VIP status).
Well, It does not work, and I don't know how to figure out what's the problem, because I don't know how to generate the logs os DATABASE CONNECTION for example.
Can anyone help ?
joao.carlos
Re: Debug of DB connection on call qualification
If anyone can help, i can see the logs on UniversalRoutingServer and the query is quite perfect (and tested with copy/paste direct on Database works), mas i still get
_I_I_006f021b0321c1e8 [09:04] ASSIGN: stratHeader(LOCAL) <- STRING: "#### - 006f021b0321c1e8 - IxnRouting - Qualifying - VisualIvrGroup - AutoAttendant - DBLookUp - "
_I_I_006f021b0321c1e8 [09:04] ASSIGN: sqlStatment(LOCAL) <- STRING: "Select RAMAL from CLIENTEMARCA where CPF=%CPF%;"
_I_I_006f021b0321c1e8 [09:04] ASSIGN: currentIndex(LOCAL) <- INTEGER: 1
_I_I_006f021b0321c1e8 [09:04] ASSIGN: previousIndex(LOCAL) <- INTEGER: 1
_I_I_006f021b0321c1e8 [09:04] ASSIGN: supervisedTransferIN(LOCAL) <- INTEGER: 2
_I_I_006f021b0321c1e8 [09:04] ASSIGN: DBErrorCode(LOCAL) <- STRING: "-1"
_I_I_006f021b0321c1e8 [07:3f] get data from cfglist(ChicagoSystem) item constants, key single-quote result: '
_I_I_006f021b0321c1e8 [09:04] ASSIGN: trimChar(LOCAL) <- STRING: "'"
_I_I_006f021b0321c1e8 [09:04] ASSIGN: mediaType(LOCAL) <- STRING: "voice"
_I_I_006f021b0321c1e8 [09:04] ASSIGN: index(LOCAL) <- INTEGER: 42
_I_I_006f021b0321c1e8 [09:04] ASSIGN: currentIndex(LOCAL) <- INTEGER: 42
_I_I_006f021b0321c1e8 [09:04] ASSIGN: index(LOCAL) <- INTEGER: 46
_I_I_006f021b0321c1e8 [09:04] ASSIGN: localResult(LOCAL) <- STRING: "%CPF%"
_I_I_006f021b0321c1e8 [09:04] ASSIGN: sqlValue(LOCAL) <- STRING: "84519355915"
_I_I_006f021b0321c1e8 [09:04] ASSIGN: sqlValue(LOCAL) <- STRING: "'84519355915'"
_I_I_006f021b0321c1e8 [09:04] ASSIGN: sqlStatment(LOCAL) <- STRING: "Select RAMAL from CLIENTEMARCA where CPF='84519355915';"
_I_I_006f021b0321c1e8 [09:04] ASSIGN: currentIndex(LOCAL) <- INTEGER: 55
_I_I_006f021b0321c1e8 [09:04] ASSIGN: index(LOCAL) <- INTEGER: 0
_I_I_006f021b0321c1e8 [09:04] ASSIGN: index(LOCAL) <- INTEGER: 7
_I_I_006f021b0321c1e8 [09:04] ASSIGN: sqlStatementStart(LOCAL) <- STRING: "Select"
_I_I_006f021b0321c1e8 [09:04] ASSIGN: sqlStatementStart(LOCAL) <- STRING: "SELECT"
09:04:17.194 Int 22000 #### - 006f021b0321c1e8 - IxnRouting - Qualifying - VisualIvrGroup - AutoAttendant - DBLookUp - SqlStatment : Select RAMAL from CLIENTEMARCA where CPF='84519355915'; calltype : 2
09:04:17.194 Int 22000 #### - 006f021b0321c1e8 - IxnRouting - Qualifying - VisualIvrGroup - AutoAttendant - DBLookUp - SqlStatementStart : SELECT.
09:04:17.216_I_I_006f021b0321c1e8 [07:38] HERE IS XDATA
_I_E_006f021b0321c1e8 [09:04] error in strategy: 0015 Closed server
_I_I_006f021b0321c1e8 [09:04] ASSIGN: DBResult(LOCAL) <- STRING: ""
09:04:17.216 Int 22000 #### - 006f021b0321c1e8 - IxnRouting - Qualifying - VisualIvrGroup - AutoAttendant - DBLookUp - DB result : () error : ( Closed server )
_I_I_006f021b0321c1e8 [09:04] ASSIGN: DBErrorCode(LOCAL) <- STRING: "15"
09:04:17.216 Int 22000 #### - 006f021b0321c1e8 - IxnRouting - Qualifying - VisualIvrGroup - AutoAttendant - DBLookUp - update of the DB_ERROR_CODE data
_I_I_006f021b0321c1e8 [09:04] ASSIGN: outError(LOCAL) <- INTEGER: -3
09:04:17.216 Int 22000 #### - 006f021b0321c1e8 - IxnRouting - Qualifying - VisualIvrGroup - AutoAttendant - DBLookUp - DB result bad script or unkown request error : 15
request to 65200(TServerA4400) message RequestUpdateUserData
AttributeReferenceID 3789
AttributeUserData [32] 00 02 00 00..
'RAMAL' ''
'DB_ERROR_CODE' '15'
AttributeConnID 006f021b0321c1e8
AttributeThisDN '09970100'
..sent to gce-rq:3100(fd=572)
joao.carlos
Tried with Oracle and MSSQL Server.
same thing!
Can you post DBServer logs?
joao.carlos
Hi cavagnaro, Thanks for your reply.
See the DBServers logs:
VisualCCDBServer:
15:18:26.792 Std 04523 Connection to client 'App (UniversalRoutingServer,GCE-RQ,0)' closed, reason ''client disconnected''
15:18:26.884 Std 05023 Process 'dbclient_msql' stopped
15:18:36.793 Trc 04521 New client 65377 connected from '10.100.129.185'
15:18:36.796 Std 05022 Process 'dbclient_msql' started
15:18:36.858 Trc 04521 New client 65379 connected from '10.100.129.185'
15:18:52.409 Std 04523 Connection to client 'App (UniversalRoutingServer,GCE-RQ,0)' closed, reason ''client disconnected''
15:18:52.448 Std 05023 Process 'dbclient_msql' stopped
15:19:02.409 Trc 04521 New client 65409 connected from '10.100.129.185'
15:19:02.411 Std 05022 Process 'dbclient_msql' started
15:19:02.474 Trc 04521 New client 65412 connected from '10.100.129.185'
15:19:19.130 Std 05023 Process 'dbclient_msql' stopped
15:19:29.024 Trc 04521 New client 65445 connected from '10.100.129.185'
15:19:29.027 Std 05022 Process 'dbclient_msql' started
15:19:29.090 Trc 04521 New client 65447 connected from '10.100.129.185'
15:19:44.631 Std 04523 Connection to client 'App (UniversalRoutingServer,GCE-RQ,0)' closed, reason ''client disconnected''
15:19:44.704 Std 05023 Process 'dbclient_msql' stopped
15:19:54.632 Trc 04521 New client 65476 connected from '10.100.129.185'
15:19:54.634 Std 05022 Process 'dbclient_msql' started
15:19:54.703 Trc 04521 New client 65478 connected from '10.100.129.185'
15:20:10.271 Std 05023 Process 'dbclient_msql' stopped
15:20:20.249 Trc 04521 New client 65507 connected from '10.100.129.185'
15:20:20.251 Std 05022 Process 'dbclient_msql' started
15:20:20.305 Trc 04521 New client 65509 connected from '10.100.129.185'
15:20:36.952 Std 05023 Process 'dbclient_msql' stopped
An update on my tries:
1. I had configured the GCE in the test environment in the same way and it works fine with MSSQL.
2. I tried to use the GCE production to consult my MSSQL server in the test environment, and got the same problem.
3. In MSSQL, i can see the connection from the GCE host, it stays in sleeping status.
In the Standard Centralized Log on SCI, i get these messages:
29/11/2012 18:22:25 Standard GCE-RQ VisualCCDBServer GCTI-00-05022 Process 'dbclient_msql' started
29/11/2012 18:22:40 Standard GCE-RQ UniversalRoutingServer GCTI-00-04502 Cannot connect to DBServer 'VisualCCDBServer' at host 'gce-rq', port 4568, reason 'unknown'
29/11/2012 18:22:40 Standard GCE-RQ VisualCCDBServer GCTI-00-05023 Process 'dbclient_msql' stopped
The host is listening to 4568 port.
TCP 0.0.0.0:4568 0.0.0.0:0 LISTENING
Please set the DBServer logs to full (all) so it will show more info
Those messages are normal
joao.carlos
Here follow the log with the All option.
GServer: new_client: fd=392, found server=132
14:23:18.094 Trc 04521 New client 57061 connected from '10.100.129.185'
14:23:18.094 Dbg 10745 './dbclient_oracle' registered; protocol version '1.4' id '2215.1'
14:23:18.094 Dbg 10734 Send message 'MSG_OPENDB' to 'Oracle: 2215.1', request id '8857'
14:23:18.094 Dbg 10734 Send message 'MSG_EXTPACKETS' to 'App (UniversalRoutingServer,GCE-RQ,0)', request id '0'
14:23:18.094 Dbg 10734 Send message 'MSG_EXTPACKET' to 'Oracle: 2215.1', request id '0'
14:23:18.094 Dbg 10743 'Oracle: 2215.1' is spare
14:23:18.259 Dbg 10739 Oracle: id='2215.1' req='-1'
DBClient Oracle, Copyright (c) 1997-2011 Genesys Telecommunications Labs, Inc.
All Rights Reserved
Db Client version: 8.1.000.05
DB Common part version: 8.1.000.05
Vendor supported versions: "Oracle 10g, 11g"
Process ID: 6588
Build on 'i686-winnt-vs8-64'
+0070 Connection to multiserver created, host 'gce-rq', port '57060', socket '236'
+0070 MSG_STARTDB status='Unknown (2215)'
Oracle: id='2215.1' req='8857' Protocols versions: dbclient='00010004' dbserver='00010004' dblib='00010004'
+0001 Database Access Point in TKVList:
+0001 Open DB: username = 'jcr', database = 'rqrescm.rqr.com.br', dbserver = '10.1.1.171'
+0165 dbstatus: 5 ocierror(12504): ORA-12504: TNS:listener não recebeu o SERVICE_NAME em CONNECT_DATA
+0165 MSG_ERROR status='dbNotOpened' msg='ORA-12504: TNS:listener não recebeu o SERVICE_NAME em CONNECT_DATA
14:23:18.259 Dbg 10749 Forwarding response '8857.1' from 'Oracle: 2215.1' to 'App (UniversalRoutingServer,GCE-RQ,0)'
14:23:18.259 Dbg 10734 Send message 'MSG_DISCONNECTED' to 'App (UniversalRoutingServer,GCE-RQ,0)', request id '-1'
14:23:18.259 Dbg 10734 Send message 'MSG_DISCONNECTED' to 'Oracle: 2215.1', request id '-1'
/Statistics
name = Oracle: 2215.1
app_name = App (UniversalRoutingServer,GCE-RQ,0)
req_rcvd = 5
req_sent = 3
data_rcvd = 1191
data_sent = 138
msg_error = 1
msg_log = 1
Client Oracle: 2215.1 is being closed. Current numofclients=0
Listener (port id = internal-0-0 fd = 132) is being closed. Checking for clients on listener...
Listener with port id = internal-0-0 has been closed and deleted from list of current ports. Number of db app connections affected: 0
Client App (UniversalRoutingServer,GCE-RQ,0) is being closed. Current numofclients=3
14:23:18.317 Std 05023 Process './dbclient_oracle' stopped
/./dbclient_oracle
pid = 6588
id = 2214
expiration_time = 2012-11-30T14:23:48
client copy = 0
DbClient name = Oracle: 2215.1
14:23:22.710 Dbg 10739 ODBC: id='2213.1' req='-1'
DBClient ODBC, Copyright (c) 1997-2011 Genesys Telecommunications Labs, Inc.
All Rights Reserved
Vendor supported versions: 1.0
Process ID: 5040
+0043 Connection to multiserver created, host 'gce-rq', port '57036', socket '236'
+0043 MSG_STARTDB status='Unknown (2213)'
ODBC: id='2213.1' req='8850' Protocols versions: dbclient='00010004' dbserver='00010004' dblib='00010004'
+0000 Database Access Point in TKVList:
+0000 section "dbclient":
+0000 "max-binding-memory" = 250
+0000 00000000004BFDE0,hDBC=5335808,5335808
+0000 Open DB: username = 'rqvc', database = 'RQVC', dbserver = '10.100.129.186'
+0002 Could not connect to SQL Server using SQL Native Client driver. Attemting default MS SQL Server driver...
+16546 odbcerr: [Microsoft][ODBC SQL Server Driver]Falha na caixa de diálogo
+16546 MSG_ERROR status='dbNotOpened' msg='[Microsoft][ODBC SQL Server Driver]Falha na caixa de diálogo '
14:23:22.710 Dbg 10749 Forwarding response '8850.1' from 'MS SQL: 2213.1' to 'App (UniversalRoutingServer,GCE-RQ,0)'
14:23:22.710 Dbg 10734 Send message 'MSG_DISCONNECTED' to 'MS SQL: 2213.1', request id '-1'
/Statistics
name = MS SQL: 2213.1
req_rcvd = 4
req_sent = 3
data_rcvd = 1236
data_sent = 170
msg_error = 1
msg_log = 1
Client MS SQL: 2213.1 is being closed. Current numofclients=0
14:23:22.710 Dbg 10734 Send message 'MSG_DBCLOSED' to 'App (UniversalRoutingServer,GCE-RQ,0)', request id '8859'
14:23:22.711 Std 04523 Connection to client 'App (UniversalRoutingServer,GCE-RQ,0)' closed, reason ''client disconnected''
Listener (port id = internal-0-0 fd = 396) is being closed. Checking for clients on listener...
Client App (UniversalRoutingServer,GCE-RQ,0) is being closed. Current numofclients=2
14:23:22.758 Std 05023 Process 'dbclient_msql' stopped
/dbclient_msql
pid = 5040
id = 2212
expiration_time = 2012-11-30T14:23:52
client copy = 0
DbClient name = MS SQL: 2213.1
/Statistics
req_rcvd = 5
req_sent = 5
data_rcvd = 278
data_send = 208
invalid_params = 0
abandoned_req = 0
abandon_req_fail = 0
error_start_client = 0
invalid_register_req = 0
msg_error = 0
pending_requests = 0
pending_queue_size = 0
max_pending_requests = 0
max_pending_queue_size = 0
GServer (0x1374050) is being removed. numofclients = 0,current numofserveritems = 2
/Statistics
req_rcvd = 6
req_sent = 5
data_rcvd = 280
data_send = 210
invalid_params = 0
abandoned_req = 0
msg_error = 0
GServer (0x509680) is being removed. numofclients = 0,current numofserveritems = 2
Oi,
Seems that you have missing configuration on your Oracle side, is tsnames configured? Can you execute this with SQLPlus?
joao.carlos
Hi cavagnaro. Thanks for your answer.
See that i sent you two logs, with oracle AND Sql Server.
I can connect to both ORACLE and SQL Servers with their clients (SQL Plus and SQL Management), I can connect to them either testing with ODBC Administrator in Windows Control Panel.
I see that these messages:
SQL SERVER
ORACLE
Seems that the configuration is wrong in some place, but i can't figure out where.
Do i have to configure anything on the database side?
The most weird is that in the test platform it works fine without any further configuration.
Ok lets see,
Post MSSQL DAP screenshot and from your MSSQL DB Engine:
Server name:
Table Name:
Return to “PREMIUM / GCE”
