I installed an ICS R6.6.106.b connected to an OXE R10.0 Patch 45 and 51.
I created the local storage voicemail on ICS and external voicemail (No. 92004) on OXE as discribed in the course and the documentation. When calling the 92004 directly I can log in. Also TUI is working.
But if I use the voicemail button on 4035 or 4028 or calling a set forwarded to this number, I get a "cancel" tone, backtraces and the following incident.
09/10/12 11:10:28 000001M|---/--/-/---|=0:1721=Phone exc 5, PC 0x083be149 neqt 358
Could anybody give me a hand with that please or some hints I have to check?
thank You and have a nice day.
Local Storage PhoneExc
- cavagnaro
Re: Local Storage PhoneExc
IP Domain compression aka codec?
on the user VM and Associated is the 92004, right?
paderb
yes. I also checked the documentation several times. I have this problem with two different systems.
Thank You
Thank You
- cavagnaro
Post logs then to see what is going on
paderb
excvisu:
There is a new exception. Its address is : 0X083BE149. Monitel time : -10914159. Date : Tue Oct 9 11:03:58 2012
Application-exception no 5, thd 1251, PC=0x083be149:138142025, eqt=358, serv=0 --> mevo_exterieure
Eqt type=POS_NUM, cr=2, cpl=10, der_us=0, term=1, subtype = 4034(MR2)
* Backtrace: 0x083be25d:138142301 EBP 0x01856d0c --> call_mevo_ext
* Backtrace: 0x08a6d281:145150593 EBP 0x01856d34 --> vers_messagerie_vocale
* Backtrace: 0x08a6d31c:145150748 EBP 0x01856dd4 --> vers_messagerie_vocale
* Backtrace: 0x08a6d380:145150848 EBP 0x01856de8 --> vers_messagerie_vocale
* Backtrace: 0x08abda25:145480229 EBP 0x01856df8 --> consultation_mevo
* Backtrace: 0x08abdde3:145481187 EBP 0x01856e00 --> decexploc
* Backtrace: 0x08a50491:145032337 EBP 0x01856e0c --> fintradec
* Backtrace: 0x08a504cf:145032399 EBP 0x01856e14 --> suitcase
* Backtrace: 0x08abd039:145477689 EBP 0x01856e1c --> reptrad_decexploc
* Backtrace: 0x08abd621:145479201 EBP 0x01856e24 --> reptrad_CH_Pfx
* Backtrace: 0x08abe6c5:145483461 EBP 0x01856e34 --> sui_decreptrad
* Backtrace: 0x08abe7dc:145483740 EBP 0x01856e5c --> decreptrad
* Backtrace: 0x08a50c41:145034305 EBP 0x01856e6c --> tra_dec
* Backtrace: 0x0937a8c6:154642630 EBP 0x01856eb0 --> real_main
GS=00000000 FS=00000000 ES=0000002b DS=0000002b
EDI=00000012 ESI=01856ccc EBP=01856d0c ESP0=00000000
EBX=01856cec EDX=00000000 ECX=01850000 EAX=00000000
EIP=083be149 CS=00000023 ESP3=01856c64 EFLAGS=00010212
B(52273:001) Eqt=00358 Emi=00000 {00000, 00003, 0x8a50b20} wait=0x8a50afc,0x000000
Restarting at PC=0x09379eac:154640044, with stack=0x01857ff8:25526264
Exception again. Monitel time : -10913967. Date : Tue Oct 9 11:04:18 2012. Eqt=358. Serv=0-> type=POS_NUM stype=77
incident:
12/10/12 07:42:49 000001M|---/--/-/---|=0:1721=Phone exc 5, PC 0x083be149 neqt 358
Neqt 358 is the phone I am calling with
here also some messages of /tmpd/sipalarm.log :
> 10/11/12 - 15:59:35 Minor alarm
[CProceedingState::receiveGlobalFailureMessage] is a NOE-SIP set, hence no GlobalFailure event emitted.
> 10/11/12 - 17:22:54 Major alarm
Subscription Failed for VM sip:92001@192.168.97.50
Subscription Failed for VM sip:92002@192.168.97.50
> 10/11/12 - 21:10:54 Major alarm
> 10/12/12 - 00:58:54 Major alarm
> 10/12/12 - 04:46:54 Major alarm
What else do You need?
incident:
- cavagnaro
No, I ment VM logs, SIP logs, on OXE you won't see many info as the VM resides on the ICS machine
paderb
here some logs.
sip-alarm.txt:
10:07:02 [1;32;45m--- Minor Error --- 2012/10/16 sip-server 6.0.004.037 started[1;32;45m[0m
10:07:08 [1;32;45m--- Minor Error --- No route to destination: sip:92004@192.168.97.81:5070;transport=UDP[1;32;45m[0m
10:07:20 [1;32;45m--- Minor Error --- No route to destination: sip:92004@192.168.97.81:5070;transport=UDP[1;32;45m[0m
10:08:03 [1;32;45m--- Minor Error --- 2012/10/16 sip-server 6.0.004.037 started[1;32;45m[0m
10:08:04 [1;32;45m--- Minor Error --- VXML connection from host 192.168.97.81[1;32;45m[0m
10:08:14 [1;32;45m--- Minor Error --- [CSipTcCall::onReceiveRequest] Method received not implemented[1;32;45m[0m
trace.log:
16 Oct 2012 10:08:03,083 3027520400 WARN task.rtp.main (:-1) - pCtx->Tos = 0
16 Oct 2012 10:08:03,096 2954091408 ERROR task.rtp.main (nel/rtp_kernel_m.cpp:757) - NO_DESC: SLEEEEEEPPPPPPP wait for signal.
16 Oct 2012 10:08:28,135 3027520400 ERROR task.rtp.main (el/rtp_kernel_s0.cpp:290) - -----------------> sending signal.
16 Oct 2012 10:08:28,136 2954091408 ERROR task.rtp.main (nel/rtp_kernel_m.cpp:763) - -----------------> signal received.
16 Oct 2012 10:08:30,322 2954091408 ERROR task.rtp.main (nel/rtp_kernel_m.cpp:757) - NO_DESC: SLEEEEEEPPPPPPP wait for signal.
16 Oct 2012 10:12:37,579 3027520400 ERROR task.rtp.main (el/rtp_kernel_s0.cpp:290) - -----------------> sending signal.
16 Oct 2012 10:12:37,579 2954091408 ERROR task.rtp.main (nel/rtp_kernel_m.cpp:763) - -----------------> signal received.
16 Oct 2012 10:12:43,747 2954091408 ERROR task.rtp.main (nel/rtp_kernel_m.cpp:757) - NO_DESC: SLEEEEEEPPPPPPP wait for signal.
stat.log:
16 Oct 2012 10:08:28,133 RTP RTP_INIT(SETUP) Ref=0x1 SOURCE_PORT=12002 Cseq=3
16 Oct 2012 10:08:28,135 RTP RTP_START SOURCE_PORT=12002 G711 DEST(192.168.97.51,32608) SESSION=0x9119DD0
16 Oct 2012 10:08:28,135 RTP SOURCE_PORT=12002 SESSION=0x9119DD0 DTMF_detection=0 RED_pt=-1 TEL_pt=-1
16 Oct 2012 10:08:30,133 RTP RTP_STOP SOURCE_PORT=12002 G711
16 Oct 2012 10:12:37,578 RTP RTP_INIT(SETUP) Ref=0x2 SOURCE_PORT=12004 Cseq=9
16 Oct 2012 10:12:37,579 RTP RTP_START SOURCE_PORT=12004 G711 DEST(192.168.97.51,32624) SESSION=0x90F6EC8
16 Oct 2012 10:12:37,579 RTP SOURCE_PORT=12004 SESSION=0x90F6EC8 DTMF_detection=0 RED_pt=-1 TEL_pt=-1
16 Oct 2012 10:12:43,551 RTP RTP_STOP SOURCE_PORT=12004 G711
I also get a new incident:
16/10/12 10:23:07 000001M|---/--/-/---|=4:0424x005=PRS_LINK Incident 5:2000,(192.168.97.81:2000)
Thanks for help
here some logs.
sip-alarm.txt:
trace.log:
stat.log:
Thanks for help
- cavagnaro
erm...no friend, SIP traces...
sipmotor=3
traced
sipmotor=3
traced
