Exporting greetings from 4645 VM
mikecel79
Post by mikecel79 »
Is it possible to export the greetings from one mailbox and import them into another? We have 7 auto attendents that are all the same. Instead of having to re-record them all over everytime it would be nice to record it once on one mailboxe, export and then import into the other mailboxes.
alex
Re: Exporting greetings from 4645 VM
Post by alex »
You can't export greetings AFAIK. But you can prepare a greeting on a PC and import it to 4645.
System Documentation/Voice Mail/Alcatel-Lucent 4645 VMS/Maintenance/Option 12: Interactif import of greeting or Option 13: Automatic import of greetings
mikecel79
Post by mikecel79 »
Thanks I didn't even think of that. However when I try to use option 12 I get an error message. The message says "Sorry system is not initialized: check language or the system law". Any ideas?
alex
Post by alex »
mikecel79 wrote:The message says "Sorry system is not initialized: check language
As it says.
Do you have 4645 running on the CPU where you run Eva_tool command?
Do you convert PC file to the format mentioned?
Be careful, the format of file should be:
a G711 format, law A or Mu
or a linear format type PCM with 16 bi
Return to “Voicemail (46x5)”
