R2 Trace
mejust
R2 Trace
Post by mejust »
Can some one help me, how I do a trace on a PCM2 (MFC R2) Card seeing the inbound call number or an outbound call?
I can see all the signalling but what I want to trace is the dialing in number .
Thks in Advanced.
Re: R2 Trace
lotof methed to do it
tuner km
tuner clear-traces
actdbg all=off
trc i
tuner appli-trace=on
actdbg mf=on
mtracer -a
or
tuner km
tuner clear-trace
tunner +at, neqt where neqt are get from r2 trunk group f ( fe tuner +at,2560-2689)
actdbg mf=on
mtracer
for dialling number (incoming or outgoing) are shown in the group 1 sgnal
DDI IS INCOMMING CALL AND CALLER IS 0770604674 CALLED 038982090
NDDI OUTGOING call and caller is 038982090 and the called is 0770604648(he was busy as you signal B3)
Re: R2 Trace
sorry her is the good syntaxe and good trace out put
(1)pst_cpu6>tuner km
(1)pst_cpu6> tuner ctr
(1)pst_cpu6> actdbg all=off
Tue Nov 20 16:28:53 CET 2012
(1)pst_cpu6> tuner +at,2628-2656
(1)pst_cpu6> actdbg mf=on
Tue Nov 20 16:31:39 CET 2012
(1)pst_cpu6> mtracer
Traces Analyser activated
mtracer started ...
(729683:000001) MTRACER host (10.253.1.2, pst_cpu6), version: R9.1-i1.605-38-dz-c7s2
(729683:000001) MTRACER num: 003, time: 2012/11/20 16:31:46, loss: 0%
(730029:000002) MF R2 -- DDI Neqt : 2654 -- Start of trace -- Dt : 2611
(730030:000003) MF R2 -- DDI Neqt : 2654 -- Rec. : I-2
(730030:000004) MF R2 -- DDI Neqt : 2654 -- Send : A-1
(730031:000005) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730031:000006) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730032:000007) MF R2 -- DDI Neqt : 2654 -- Rec. : I-10
(730032:000008) MF R2 -- DDI Neqt : 2654 -- Send : A-1
(730033:000009) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730033:000010) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730034:000011) MF R2 -- DDI Neqt : 2654 -- Rec. : I-9
(730034:000012) MF R2 -- DDI Neqt : 2654 -- Send : A-1
(730035:000013) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730035:000014) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730036:000015) MF R2 -- DDI Neqt : 2654 -- Rec. : I-10
(730036:000016) MF R2 -- DDI Neqt : 2654 -- Send : A-5
(730037:000017) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730037:000018) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730038:000019) MF R2 -- DDI Neqt : 2654 -- Rec. : II-1
(730038:000020) MF R2 -- DDI Neqt : 2654 -- Send : A-5
(730039:000021) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730039:000022) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730040:000023) MF R2 -- DDI Neqt : 2654 -- Rec. : I-10
(730040:000024) MF R2 -- DDI Neqt : 2654 -- Send : A-5
(730041:000025) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730041:000026) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730042:000027) MF R2 -- DDI Neqt : 2654 -- Rec. : I-7
(730042:000028) MF R2 -- DDI Neqt : 2654 -- Send : A-5
(730043:000029) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730043:000030) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730044:000031) MF R2 -- DDI Neqt : 2654 -- Rec. : I-7
(730044:000032) MF R2 -- DDI Neqt : 2654 -- Send : A-5
(730046:000033) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730046:000034) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730046:000035) MF R2 -- DDI Neqt : 2654 -- Rec. : I-10
(730046:000036) MF R2 -- DDI Neqt : 2654 -- Send : A-5
(730048:000037) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730048:000038) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730049:000039) MF R2 -- DDI Neqt : 2654 -- Rec. : I-6
(730049:000040) MF R2 -- DDI Neqt : 2654 -- Send : A-5
(730050:000041) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730050:000042) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730051:000043) MF R2 -- DDI Neqt : 2654 -- Rec. : I-10
(730051:000044) MF R2 -- DDI Neqt : 2654 -- Send : A-5
(730052:000045) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730052:000046) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730053:000047) MF R2 -- DDI Neqt : 2654 -- Rec. : I-4
(730053:000048) MF R2 -- DDI Neqt : 2654 -- Send : A-5
(730054:000049) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730054:000050) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730055:000051) MF R2 -- DDI Neqt : 2654 -- Rec. : I-6
(730055:000052) MF R2 -- DDI Neqt : 2654 -- Send : A-5
(730056:000053) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730056:000054) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730057:000055) MF R2 -- DDI Neqt : 2654 -- Rec. : I-4
(730057:000056) MF R2 -- DDI Neqt : 2654 -- Send : A-5
(730058:000057) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730058:000058) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730059:000059) MF R2 -- DDI Neqt : 2654 -- Rec. : I-7
(730059:000060) MF R2 -- DDI Neqt : 2654 -- Send : A-5
(730060:000061) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730060:000062) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730061:000063) MF R2 -- DDI Neqt : 2654 -- Rec. : I-15
(730061:000064) MF R2 -- DDI Neqt : 2654 -- Send : A-3
(730062:000065) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730062:000066) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730063:000067) MF R2 -- DDI Neqt : 2654 -- Rec. : II-1
(730063:000068) MF R2 -- DDI Neqt : 2654 -- Send : B-6
(730064:000069) MF R2 -- DDI Neqt : 2654 -- Rec. : silence
(730064:000070) MF R2 -- DDI Neqt : 2654 -- Send : silence
(730064:000071) MF R2 -- DDI Neqt : 2654 -- End of trace --
(730105:000072) *** warning: no time-slot alloc/desalloc nedeed for this coupler (Cr:0-Cpl:18)
(730177:000073) MF R2 -- NDDI Neqt : 2646 -- Start of trace -- Dt : 2611
(730190:000074) MF R2 -- NDDI Neqt : 2646 -- Send : I-10
(730191:000075) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-5
(730191:000076) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730192:000077) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730192:000078) MF R2 -- NDDI Neqt : 2646 -- Send : II-1
(730193:000079) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-5
(730193:000080) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730194:000081) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730194:000082) MF R2 -->search_ident_number-->rvtemp_ext_en_cours=0
(730194:000083) MF R2 -- NDDI Neqt : 2646 -- Send : I-10
(730195:000084) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-5
(730195:000085) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730196:000086) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730196:000087) MF R2 -- NDDI Neqt : 2646 -- Send : I-3
(730197:000088) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-5
(730197:000089) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730198:000090) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730198:000091) MF R2 -- NDDI Neqt : 2646 -- Send : I-8
(730199:000092) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-5
(730199:000093) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730200:000094) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730200:000095) MF R2 -- NDDI Neqt : 2646 -- Send : I-9
(730201:000096) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-5
(730201:000097) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730202:000098) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730202:000099) MF R2 -- NDDI Neqt : 2646 -- Send : I-8
(730203:000100) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-5
(730203:000101) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730204:000102) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730204:000103) MF R2 -- NDDI Neqt : 2646 -- Send : I-2
(730205:000104) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-5
(730205:000105) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730207:000106) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730207:000107) MF R2 -- NDDI Neqt : 2646 -- Send : I-10
(730207:000108) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-5
(730207:000109) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730209:000110) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730209:000111) MF R2 -- NDDI Neqt : 2646 -- Send : I-9
(730209:000112) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-5
(730209:000113) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730211:000114) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730211:000115) MF R2 -- NDDI Neqt : 2646 -- Send : I-10
(730212:000116) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-5
(730212:000117) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730213:000118) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730213:000119) MF R2 -- NDDI Neqt : 2646 -- Send : I-15
(730214:000120) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-1
(730214:000121) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730215:000122) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730215:000123) MF R2 -- NDDI Neqt : 2646 -- Send : I-7
(730216:000124) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-1
(730216:000125) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730217:000126) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730217:000127) MF R2 -- NDDI Neqt : 2646 -- Send : I-7
(730218:000128) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-1
(730218:000129) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730219:000130) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730219:000131) MF R2 -- NDDI Neqt : 2646 -- Send : I-10
(730220:000132) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-1
(730220:000133) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730221:000134) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730221:000135) MF R2 -- NDDI Neqt : 2646 -- Send : I-6
(730222:000136) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-1
(730222:000137) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730223:000138) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730223:000139) MF R2 -- NDDI Neqt : 2646 -- Send : I-10
(730224:000140) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-1
(730224:000141) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730225:000142) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730225:000143) MF R2 -- NDDI Neqt : 2646 -- Send : I-4
(730226:000144) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-1
(730226:000145) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730227:000146) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730227:000147) MF R2 -- NDDI Neqt : 2646 -- Send : I-6
(730228:000148) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-1
(730228:000149) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730229:000150) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730239:000151) MF R2 -- NDDI Neqt : 2646 -- Send : I-4
(730240:000152) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-1
(730240:000153) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730241:000154) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730242:000155) MF R2 -- NDDI Neqt : 2646 -- Send : I-8
(730248:000156) MF R2 -- NDDI Neqt : 2646 -- Rec. : A-3
(730248:000157) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730249:000158) MF R2 -- NDDI Neqt : 2646 -- Rec. : silence
(730249:000159) MF R2 -- NDDI Neqt : 2646 -- Send : II-1
(730250:000160) MF R2 -- NDDI Neqt : 2646 -- Rec. : B-3
(730250:000161) MF R2 -- NDDI Neqt : 2646 -- Send : silence
(730251:000162) MF R2 -- NDDI Neqt : 2646 -- End of trace --
(730261:000163) *** warning: no time-slot alloc/desalloc nedeed for this coupler (Cr:0-Cpl:18)
mejust
Re: R2 Trace
Post by mejust »
Hello Thks for the help but I was looking for a trace where you see the number in full meaning instead of seeing the number on the vertical side I want see the whole number horizontally . 222690789 instead of 2
2
2
6
9
0
7
8
9
mejust
Re: R2 Trace
Post by mejust »
[quote="mejust"]Hello Thks for the help but I was looking for a trace where you see the number in full meaning instead of seeing the number on the vertical side I want see the whole number horizontally . 222690789 instead of 2
2
2
6
9
0
7
8
9
I need this because I have 50 calls coming all at the same time and seeing the number vertically is harder to track if you know what I mean.
Re: R2 Trace
For outgoing calls - create another TG (the same like your R2 TG) with only one TS. In this you can trace without problem (you will have just one neqt).
mejust
Re: R2 Trace
Post by mejust »
Thks VAD Im sorry answering only now but it worked .
mokhtar ACFE
Re: R2 Trace
Post by mokhtar ACFE »
Please VAD ,When I create another Trunk Group with one Nequt 2618 , I have the state of this equt always hs .
Return to “ON SITE TROUBLES”
