Hi all
My OXO R8.2
IP-Phone use static IP to connect OXO. it is OK
But when i try to use "Dynamic" . it is fault
IP-Phone can not download TFTP (TFTP no response) file from OXO
How to use DHCP for IP Phone???
it is need router to modify some configuration?
Thanks!!!
Re: How to use DHCP for IP Phone
What type of DHCP-Server do you use? Embedded in the OXO? External such as Windows Server 2008?
ACSE OXO R8.0
ACSR OXO
ACSR Eye-Box
ACSE OXE R9.1
.. and a lot of more...!
ACSR OXO
ACSR Eye-Box
ACSE OXE R9.1
hunggundam
if Windows Server 2008 or 2003.....any difference??OXO-Man wrote:What type of DHCP-Server do you use? Embedded in the OXO? External such as Windows Server 2008?
solven
What have you configured in your dhcp scope options?
I'm pretty sure you need atleast option 66 (tftp server address) and 67 (bootfile name(lanpbx.cfg)) configured inorder for it to work.
