Hello!
How can I view the uploadud photo on the 8082 MyIC Phone?
When we upladed it to the phone from USB stick, it is visible, but only on the 8082.
But we have a 8082, an Android and a MyIC Communicator on PC.
We want to see the pictures on every device. So, it should attach to a person. How is it possible?
Many Thanks!!!
Picture on 8082
corwin
Re: Picture on 8082
Picture visible on au OT client must be located on server
One source is external ldap like 8770
Put picture in 8770
On OT make sure you have 8770 in thé list of search directories and that jpeg photo attribute is added in thé attribute for field to be collected
Due to the contact processing some feature nées data from internal dir ( likevoicemail sender display of name ) or 8770 for picture
Use merge to get one contact with all attributes
This is not complète
Aces has also picture in its dB and next OT version nées to be improuver to havé à picture global setup
Put picture in 8770
baalynt
Re: Picture on 8082
There is a picture uploaded to 8770 Directory, I can see it in the Webdirectory too.
So I don't know the step that shows this picture on the PC Client or 8082. Is it a special step to show it on the screen?
Do I need to upload the picture to Directory? Or I must do something on OT server too?
How do you mean the merge procedure? Many questions, but I don't know the answers...
Thanks!
Thanks!
baalynt
Re: Picture on 8082
Where to configure 8770 in the list of search directories on the OT?
Where to add jpeg photo attribute in the attribute for field to be collected?
Could you send screenshots about?
Thanks!
Thanks!
