SNMP OID's for Write Memory and Copy Working Certified
Awesome
Post by Awesome »
Good afternoon.
Can advanced forum members tell me what are the correct SNMP OID's to perform a
Write Memory
And
for a 6850 switch please?
Re: SNMP OID's for Write Memory and Copy Working Certified
In the mibs.zip from alcatel business partnerportal you find an document "alcatel.tree" (see attachment - I have to rename is into .txt for uploading). Hope you will find there the correct commands.
