IAP175 Radio port R1-2 (6) not works
Also known as OmniAccess Instant AP
danielsales
Post by danielsales »
I'm using two directional antennas 2.4 GHz 12 dBi gain.
Annex sending a photo.
I checked the manual and the antennas are connected on Radio 1 on ports 1 (R1-1) and 6 (R1-2) (2.4 GHz).
Tested switching the antennas between the ports 1 and 6. The antenna connected to port 1
always works, and antenna connected to port 6 never radiates the signal.
I tested the two antennas (one at a time) on port 1 and the two antennas work perfectly.
Return to “OmniAccess Wireless Access Points”
