minicom set up details
knightr1der
Post by knightr1der »
Hi guys,
I need some help.
I just did an upgrade on a OXE (Crystal Architecture). Only from F4.401.13 to F4.401.24.d and the customer didn't tell me before that someone configured Minicom to allow them voicemail (4635) config from mtcl account (to reset vm passwords etc..).
Now since upgrade they cannot use the minicom command.
Does anyone know how i can set this up again? The 4635 is connected to port D and the system has IO2N boards fitted.
TIA...
knightr1der
Re: minicom set up details
Its OK.
I have the solution now.
Login as root user.
type minicom -s and press enter... the rest is menu driven :D
Return to “Voicemail (46x5)”
