OMC installation Error with Windows 7
shirantha
Post by shirantha »
Dear all,
I tried install several omc version with windows 7 , but that installation in progressing of end its appear attached error message,
Could you please chack & verefy to what are the reason for above .
thanks,
Shirantha
giovanni.attolini
Re: OMC installation Error with Windows 7
Post by giovanni.attolini »
Are you the administrator of your PC? Did you try "execute like administrator" or change the compatibility of your exe file?
Giovanni A. Attolini
fschmitti
Post by fschmitti »
dotnet 3.5 installed ?
First ...be Administrator !
Path of installation not in c:/program....directly in c:/ ...works fine...
Database also in a separate path ...like c:/OMC-Database/
... it should work then
Greets
Return to “Configuration”
