Pimphony error
andrei
Pimphony error
Post by andrei »
Could you help me please solve my problem with the Pimphony program. My pimphony have worked 4 mounth without problems, but sudenly an error appears (screenshot is below). I tried to push details button, but the program not respond. Telefon works without program too, but I need this program. I didn't change any settings or IP adresess. Now I don’t know what to do. Could you give me please an advise.
Thank you!
et
Re: Pimphony error
Post by et »
Try to launch configuration Master for PIMphny on your PC and programm it for another set, then again for your set.
andrei
Re: Pimphony error
Post by andrei »
Thank you for your answer!
I tried to launch configuration Master for PIMphny on my PC and programmed it for another set, then again for my set. It did not help.
I have a new screenshoot, now I can push details button.
Could you tell me what does this error mean ?
Re: Pimphony error
Try to reinstall and reconfigure your applications and see if you get the same error.
Return to “MAIN”
