User management issue on 6850
dogx010299
Post by dogx010299 »
Dear All,
I'm a newbie in OmniSwitch.
Recently I have a problem with user's privilege on 6850.
My supervisor asked me a question
We have a user with following settings on 6850
user Jeff_Li password ************ read-only all
Now my supervisor ask me to give him read-write for "ip interface" only
So I use the cli and key in user Jeff_Li read-write ip
But system tell me this : ERROR: Inconsistent configuration between Read Only and Read/Write privileges
So...how should I give Jeff the privilege of read-write ip ?
Thanks to all, best regards.
Andy
duBeN
Re: User management issue on 6850
Post by duBeN »
I believe only option is to specify all read-only possibilities except ip - instead of using all.
for example: user test read-write ip read-only 802.1Q AAA AIP AVLAN ...
seems to me that problem is that you are saying that you want read-write access to ip and read-only access to ip - and it's confusing the switch.
