I'm traying to configure a VPRN through snmp.
[root@~]# snmpset -v 2c -c mycomunity my-switch TIMETRA-SERV-MIB::svcRowStatus.8887 i 4 TIMETRA-SERV-MIB::svcType.8887 i 4 TIMETRA-SERV-MIB::svcCustId.8887 u 1 TIMETRA-SERV-MIB::svcVRouterId.8887 i 14 TIMETRA-SERV-MIB::svcDescription.8887 s "IMASD"Code: Select all
TIMETRA-SERV-MIB::svcRowStatus.8887 = INTEGER: createAndGo(4)
TIMETRA-SERV-MIB::svcType.8887 = INTEGER: vprn(4)
TIMETRA-SERV-MIB::svcCustId.8887 = Gauge32: 1
TIMETRA-SERV-MIB::svcVRouterId.8887 = INTEGER: 14
TIMETRA-SERV-MIB::svcDescription.8887 = STRING: "IMASD"Configuration on switch:
*A:lab-1>config>service>vprn# info
description "IMASD"
autonomous-system 6500
route-distinguisher 65000:8887
vrf-target target:65000:8887
no shutdown
----------------------------------------------Code: Select all
TIMETRA-SERV-MIB::svcVRouterId.8887 = INTEGER: 14Code: Select all
[root@~]# snmpset -v2c -c mycomunity my-switch TIMETRA-VRTR-MIB::vRtrIfRowStatus.14 i 4 TIMETRA-VRTR-MIB::vRtrIfType.14 i 5 TIMETRA-VRTR-MIB::vRtrIfName.14 s "IMASD_INTERFAZ_1"
Error in packet.
Reason: noCreation (That table does not support row creation or that object can not ever be created)
Failed object: TIMETRA-VRTR-MIB::vRtrIfRowStatus.14Code: Select all
vRtrIfRowStatus OBJECT-TYPE
SYNTAX RowStatus
MAX-ACCESS read-create
STATUS current
DESCRIPTION
"The row status. The creation or deletion of a router interface entry
causes creation or deletion of corresponding entries in other Tmnx MIB
tables with the same vRtrID and vRtrIfIndex values, such as the
vRtrIpAddrTable. The router interface is associated to a physical port
interface through the vRtrIfPortID and vRtrIfEncapValue variables. [b]The
RowStatus cannot be SET to 'active' unless vRtrIfName has been
initialized."[/b]
::= { vRtrIfEntry 2 }Why that table does not support row creation?, Have I missed something (a mandatory column)?
