CPU7-2 Cant Ping...
Tom01
CPU7-2 Cant Ping...
Post by Tom01 »
Hi guys
Just need your expert assistance on this matter.
We have a duplicated CPU7-2 configuration with us here. Its out of box for a installation.
The CPU A IP is 192.168.45.100 while the CPU B IP is 192.168.10.2
The CBRA board is connected without the Ethernet Link on the CPU Boards ON.
When we ping the IP of the CPU from the PC ( We have put the PCs in the same networks as the CPUs), we can't ping either of the CPU.
When we ping the IP of the CPU from the serial (local to the server), it can ping itself.
Requesting if you can give some ideas on this.
Tom
Murphy72
Re: CPU7-2 Cant Ping...
Post by Murphy72 »
Is the the problem solved or still in work ?
I think problem solved (for both CPU managed IP addresses from one subnetwork).
muhammad imtiaz
Post by muhammad imtiaz »
Are these new from Alcatel-Lucent.... If yes than you need to set the security level by serial port?
