Hi Guys
I intalled MyIC v 2.7.00.33.000 but when i select My Current Phone>>My Computer displays a message that says The Voice over IP module can not be initialized.
Note: In windows XP working very good, the problem is in Windows 7
Any ideas? my ICS is 6.7.0
felinux
Re: The Voice over IP module can not be initialized.
Check logs, firewall, network, etc. Usually is a network connectivity issue.
felinux
Hi cavagnaro,
I check the log, off the firewall, antivirus, run the MyICS with administrator privilegies , i check the network but the problema persist and i get new message
Have you configured GD/INTIP board on ICS nomadic parameters?
can you ping the GD/INTIP board configured there?
zmagyar
Hello, Felinux, did you fixed the issue, I have the same problem.
Thanks,
Thanks,
