Broadcasting to a single subscriber
steg81_DUP
Post by steg81_DUP »
Hi all,
I would like to know how to set up a broadcast for inderviduals, I know how to st up a broadcast for 1 group but not for inderviduals.
Do i put one subscriber per group, this is fine, what do i change in the internal numbering plan so i can do this for indervidual groups?
e.g. one person per group each having there own broadcast prefix.
how would i change the internal numbering plan so i can have ten and not overlaping other prefixes.
The numbering plan is the defult numbering plan. e.g. #* [Broadcast]
Dallan
Re: Broadcasting to a single subscriber
Post by Dallan »
For this to work you will have to add all the people who are able to broadcast to the group as you have to be a member of a group to broadcast in that group, this can be tricky as the group is limited to 32 members, but if that is enough then add all the broadcasters as "send only" and the phone you are broadcasting to as "recieve only"
steve
Post by steve »
Why you don't use the intrphonic intrrusion featurekey ?
If you want to make a broadcast for one user, just call the extension, and use the interphonic intrusion key. (Of course this feature is available the with digital hands free sets.)
Don't forget the intrusion right in the Subscribers/details/features part.
Return to “MAIN”
