Hi friends,
If I keep any Analog phone off-hook for extended period, after some time error tone (howler tone) comes but port never locks out.
But it should lockout after sometime. Is there any setting for this - please suggest.
Thanks, Sudeb
eZ32 port off-hook for extended period
Re: eZ32 port off-hook for extended period
Yes. There is a Timer after this Port goes in MISCALL State. See System documentation for Timers.
timer 12 default is 150 15 sec
big fault in alcatel system
yea i guess itss too bad that at least when we re set the equipment the issue isnt corrected. most of the time i face this issue when i up grade the system. and when i get any analog sets as miscall i have to delete and re create it again.
did you try termstat d "xtn No." and reset port (opt 5 I think)?
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
thanks for the reply
termstat 'd' or 'n' dont do the trick.
never tried reset port but i when i run it there is no command as such, please see below.
(1)xs000001> reset
reset resetall resetx25tbl
(1)xs000001> re
reInitWizard reboot remote_kill resetx25tbl
read recover remoteghosts resize2fs
read_bbox recover_tabjus remoteinfo resizecons
read_head recup remoterestart restart_dect
readbbox recupexc remotesets restore_cei
readelf red remoteview restorevm
readfile registrarcopy.src_sh rename return
readhead reinit renice rev
readkey relala represent rexec
readlink relalaoff rescuept
readonly rema_dump reset
readprofile remad resetall
(1)xs000001> reset
(1)xs000001> reset
the above is from r 11.0
(1)xs000001> reset
(1)xs000001> re
(1)xs000001> reset
(1)xs000001> reset
Hi may be you don't understand murray
but this is my way To stop such as issue
i launch listinacall <cystal n°>
I localise the miscall sets
i do termstat d <directory number)
option 1 confirm miscall state (or option 4 tobe sure is in incomm)
option 5 reset equipent
quit
after that i do outserv d <diretory n°> ,and like this i stop the open loop issue
it's the first job wich i do every morning
but question still why so basic option "automatic disconnect of equipement after detection of loop ,grounding bad line , or off hook tone for more than 15 sec" witch is avalaible on lot of third party equipement(nortel , panasonic, ericsson) is not avalaible on oxe or availaible on oxe with e-z32 only? not this issue can cause the lost of z-24 board entire.
because z-24 doesn't have an embeded local cpu ? strange
quit
here an exemple
got it,, thanks alot,,, didnt know about ''listincall'' command.. thanks again
