Casual conference in 4400
A 4400 system R5 (unix) is equiped with sofware license and a GPA board in order to support casual conference. The facility was working fine, when it was installed, a couple of years ago. The customer complains now that the feature is not available. I checked the configuration, I replaced the GPA board, I even made restart of the system, but conference does not start.
- tot3nkopf
Re: Casual conference in 4400
What modularity is configured in GPA for master or meet me conference?
On user COS is casual conference allowed?
GPA modularity is 4X7 and phone category of the phone allows the feature. In general, all related parameters (under "system") are as in the documentation.
cfnstat - conference circuit - ready (4x7, add-on)?
Not working - when you establish 3-way conference - absent key "Add-on"?
The set (4020, 4010, etc) is equipped with a "conference" key and everything is fine up to 3-way conference, then the process to establish 6-party can not be completed. Pressing the key, nothing happens and an attempt to make a new call releases the last participant of the conference
- tot3nkopf
Maybe you have updated the license key and casual conference is no longer present.
Please go to /usr3/mao and run cfgUpdate and let us see the output:
52 Maximum simultaneous casual conferences : ?
I am afraid that is what happened, the license is lost. However, I checked cfgUpdate and the key 52 does not exit (last key present is 51-Set display language)
- tot3nkopf
No. You should have a field for that and the value should be 0 (maybe is not 52 for your sw release). You should update the value with desired value, save and reboot (double bascul for redundancy --> keep in mind to update also on st-by cpu).mtcl wrote:I am afraid that is what happened, the license is lost. However, I checked cfgUpdate and the key 52 does not exit (last key present is 51-Set display language)
I do not know really if in older sw releases this was treated differently....
Regards.
1 Stations : 4000
2 S0 Buses : 512
3 Data terminals : 1000
4 Patients (hospital) : 1000
5 Trunks : 500
6 Equipment_Coefficient : 1.4
8 Nodes in the network : 100
9 UA Links : 2977
10 Shelves (migration excluded) : 6
11 1/2 com : 500
12 TS reserved for operators on INT/RT2 links : 4
13 Tables of R2 signalling translator : 1000
15 Data in R2 signalling translator : 1000
17 Abbreviated numbers : 4000
18 DECT Handsets : 250
19 Supervisable MCDU : 1500
20 Number of Sub-Networks : 16
21 Number of Network Set in Hunting Group : 300
22 Number of ARS route lists : 400
24 Number of areas (accounting duration) : 1000
25 Number of Charge Scales (accounting duration): 30
26 Supervisable Trunks / Trunk groups : 150
27 Number of Network Supervisor : 0
28 Number of PIN : 0
34 Number of x25 command abbreviated numbers : 100
35 Number of called filter : 500
36 Maximum Number Of Account Codes : 2000
Values read in hardware.mao file :
41 Remanent size : -1
42 Stand-alone : -1
43 Number of BLF : -1
44 Phone-book (x 2000) : -1
45 SBC : -1
46 4635X : -1
47 4630 : -1
48 4855 : -1
49 Hotel accesses : -1
50 ACD supervisor accesses : -1
51 Set display languages : -1
Value to modify (0 = Exit) :
and the release: 5.0Ux-d2.314-7-ah-gr-c6s2
It is strange isn't it ?
2 S0 Buses : 512
5 Trunks : 500
9 UA Links : 2977
11 1/2 com : 500
42 Stand-alone : -1
45 SBC : -1
46 4635X : -1
47 4630 : -1
48 4855 : -1
- tot3nkopf
Could be normal for that release. Can you also post the spadmin active file output?
