We are trying to implement 802.1x on our campus but we’ve encountered a problem with captive portal (CP).
We don’t need a CP, therefore nothing is configured to point the PC’s to the CP, except the default values which can’t be removed.
Problem;
In some cases an authenticated PC looses its connection. By a expired timer or when the PC goes into (hybrid) sleep/hibernate, even without reason.
Those PC’s are supplicants and should pass the 802.1x authentication, but sometimes they don’t. So the policy states that they should go to another user network profile where they can access the internet, but not our intranet.
Instead, sometimes they go to the CP.
Actions we’ve took sofar;
-Most of the time a re-initialize solves the problem, but this is not doable when we migrate our full network
-All the switches have the latest IOS (6.6.4.177.R01)
-We played with the timers on the switch, PC (block-timers, etc.) and radius-server
-We’ve captured packets on the exact moment when a PC goes into the CP-state, but we don’t see any triggers that would cause a de-authentication or…
Here's the config we use;
aaa-config:
aaa radius-server "NPS1" host 10.0.161.191 key xxx retransmit1 timeout 2 auth-port 1812 acct-port 1813
aaa radius-server "NPS2" host 10.0.161.193 key xxx retransmit1 timeout 2 auth-port 1812 acct-port 1813
aaa authentication console "NPS1" "NPS2" "local"
aaa authentication telnet "NPS1" "NPS2" "local"
aaa authentication ftp "NPS1" "NPS2" "local"
aaa authentication http "NPS1" "NPS2" "local"
aaa authentication ssh "NPS1" "NPS2" "local"
aaa authentication 802.1x "NPS1" "NPS2"
aaa authentication mac "NPS1" "NPS2"
aaa user-network-profile name "CNET" vlan 100 hic disable
aaa user-network-profile name "PNET" vlan 29 hic disable
802.1x auth-server-down enable
802.1x auth-server-down re-authperiod 1500
802.1x auth-server-down policy user-network-profile CNET
802.1x 1/1 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 60 max-req 2 re-authperiod 3600 reauthentication
802.1x 1/1 captive-portal session-limit 12 retry-count 3
802.1x 1/1 supp-polling retry 2
802.1x 1/1 captive-portal inactivity-logout enable
802.1x 1/1 supplicant policy authentication pass block fail user-network-profile PNET block
802.1x 1/1 non-supplicant policy authentication pass block fail group-mobility user-network-profile PNET block
802.1x 1/1 captive-portal policy authentication pass block fail block
