SIP Extension cant communicate with another extensions
manoj
Post by manoj »
Hi all,
I have created one lifesize conference phone with OXE 9.0. LifeSize phone successfully registered as SIP extension.
But when I am dialing from SIP extension I am getting busy tone. and I cant receive the call from another extensions also. I tried with SIP device but its same.
SIP Extension is 4380 and IP address is 172.16.1.97 and CS is 172.16.0.91
FInd the attached sip traces for reference...
alex
Re: SIP Extension cant communicate with another extensions
Post by alex »
First of all, read the docs. SIP extension is used only for phone features (SEPLOS mode).
Any other equipment (video, confrence bridges etc) should be configured as SIP device.
manoj
Post by manoj »
I have configured as SIP device also. but the device cant make and receive the calls. I need the phone features only through this conference phone.
alex
Post by alex »
LifeSize-ExpressRoom200_OmniPCXEnterpriseR9.1_IWR_ed01.pdf
There is an interworking report on that.
manoj
Post by manoj »
Hi Alex,
Thanks for the Documents..but this documents is for the integration with Lifesize codec(Express series and Room Series)and OXE. But in my case I have lifesize conference Phone only there is no codec.
alex
Post by alex »
Actually it shouldn't matter -you get an idea how both sides are configured.
manoj
Post by manoj »
Hi...from this sip Phone now I can make calls ( Internal and External). But I cant receive the calls. I tried as SIP Extension and SIP Device...In both case I can make the calls but I cant receive the calls. I have tried with different codec also but same symptom.
Please suggest.............
click the 3rd check box of the second tab. That should work.
Logs...
alex
Post by alex »
cavagnaro wrote:click the 3rd check box of the second tab. That should work.
Great, cav.
You just repaired your old crystal ball or got a new one? :lol:
That's a way it is
Great, cav.
That's a way it is
Lol new one of course. iBall with 128Gb ram so it can see beyond and even got the iPossesion addon so I can now do remote support by using the end user as a medium and be on site without traveling . Amazing stuff!!
Sent from my XPeria Z
Return to “SIP”
