Modifying voice guide
L_lefante
Post by L_lefante »
The voice guide corresponding to check the mail box says to dial 43, but the actual code is *43. I don´t want to change the code in the numbering plan, but i would like to modify the voice guide.
Is there a way to do this?
many thanks.
alex
Re: Modifying voice guide
Post by alex »
You've posted in a wrong forum.
It is not a 4645 message but a system voice guide #102.
Check VOICE - Common topics for Crystal / Common hardware ‹ Voice Guides
Eliott
Post by Eliott »
Possible with AAS. Alcatel Audio Station (on the VG CD are snippets for that (Star for example))
Return to “Voice Guides”
