Hello all,
For our company l am developing a small application to set/get dnd on a phone set. while sending a cstasetDonotDisturb ( ecma 218 csta phase 2) i always received a Cstafailure Confirmation as error "RequestIncompatibleWithObject". l am asking that this API works? CstamakeCall works fine!
Also fire a cstamakecall with a feature code for dnd is also fine.But how do l get the dnd state?
Christian
Issue of Set/GetDnD
- cavagnaro
Re: Issue of Set/GetDnD
Does DND works manually?
Sent from my XPeria Z
christianla
Hallo Cavagnaro,
Yes , it does. And as l say l can also setDnD using a cstaMakeCall with a feature code (e.g *78 xxxx). But using cstaSetDonotdisturb fails with the error "RequestInCompatibleWithobject".
My question is: does 4400 support cstaSetDonotDisturb and cstaGetDonotDisturb ? if yes, why does the PBX return e UniversalFailure ? does it need some configuration for those extentions?
Christian
Christian
- cavagnaro
Have no clue. you will have to open directly the question with ALU
