Hi all,
I have recently installed OXE R7.1 common hardware with four shelves. One is the main shelf, and two are connected with it via MEX boards. Operations are all fine with these shelves. But problem occurs in the user extensions which are created on the fourth shelf. In fact, this shelf is connected with the main via IP only i.e. this shelf contains a GD board at zero position and an ethernet link from this GD connects this shelf to the main shelf. All internal communication is OK on this fourth shelf as well. But when a user of this shelf seizes a trunk group, then he/she faces wrong dialing problem on outgoing i.e. wrong number is dialled most of the time (Ratio of wrong and right dialling is 90:10). Multiple echoes of DTMF dialling are heard against one digit press on the phone. It seems I dial a digit once, but it is dialled twice or thrice by the system. Any idea ?? Also note that this problem is not faced when we use the Direct Trunk Seizure method. Isn't it interesting ??
All the trunk boards are on the second and third shelves (All are analog trunks in the system). The problematic shelf i.e. fourth shelf only has analog extension boards (SLI-16).
Remote Shelf problem in Common Hardware ... it's about trunk
Ihthisham
Re: Remote Shelf problem in Common Hardware ... it's about trunk
what are the trunk type you use on the IP Media Gateway ( On shelf 4)?
torrentula
I have had similar problems with extensions in the 4th shelf but with modem communications. Try putting one of your trunk boards in shelf 1.
tadaxi
can see rarly this situation
- frank
Aamir-KHI
If it s not too hard for you -you should DEFINITLY TRY THAT-, bring the 4th shelf where the main is, and connect it directly together. It looks to me like a bad IP link between the main and your remote.
arnies
Was there any solution that was confirmed to resolve this issue?
