Trouble connecting with software SIP
smith_user
Post by smith_user »
Hi there
Im trying to connect blink to OXO 9.1, when i do a SIP trace i get the following
2013-09-03 15:48:24.403000 [blink.exe 12056]: SENDING: Packet 31, +0:05:06.501000
192.168.0.252:59027 -(SIP over UDP)-> 192.168.0.99:5059
REGISTER sip:192.168.0.99 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.252:59027;rport;branch=z9hG4bKPj6f9db3dbb3e547729292ab35f1464697
Max-Forwards: 70
From: "Jake" <sip:JakeIP@192.168.0.99>;tag=ed28f4ffde994e56a83a11f36ccfacee
To: "Jake" <sip:JakeIP@192.168.0.99>
Contact: <sip:35478026@192.168.0.252:59027>;+sip.instance="<urn:uuid:eeeeeaf1-0802-4b69-a29d-aac716b40e9c>"
Call-ID: 72363ae3a46a4d75a6125b1e695168e7
CSeq: 1 REGISTER
Expires: 600
Supported: gruu
User-Agent: Blink 0.5.0 (Windows)
Content-Length: 0
2013-09-03 15:48:24.404000 [blink.exe 12056]: RECEIVED: Packet 32, +0:05:06.502000
192.168.0.99:5059 -(SIP over UDP)-> 192.168.0.252:59027
SIP/2.0 401 Unauthorized
WWW-Authenticate: Digest qop="auth",nonce="d1bd95cf807422bf1de875f8051a5d2c",realm="192.168.0.99"
To: "Jake" <sip:JakeIP@192.168.0.99>;tag=b0f2d9e175782cfb7da83af92bf16da0
CSeq: 1 REGISTER
Via: SIP/2.0/UDP 192.168.0.252:59027;rport=59027;branch=z9hG4bKPj6f9db3dbb3e547729292ab35f1464697
Content-Length: 0
2013-09-03 15:48:24.406000 [blink.exe 12056]: SENDING: Packet 33, +0:05:06.504000
Via: SIP/2.0/UDP 192.168.0.252:59027;rport;branch=z9hG4bKPjc09958e53118452ba40500c934e3ef80
Max-Forwards: 70
CSeq: 2 REGISTER
Expires: 600
Supported: gruu
Authorization: Digest username="JakeIP", realm="192.168.0.99", nonce="d1bd95cf807422bf1de875f8051a5d2c", uri="sip:192.168.0.99", response="645ffe2f8a17424a685dd3c11d697684", cnonce="b1aef92a5f13497bbc51abf9b5b219e8", qop=auth, nc=00000001
Content-Length: 0
2013-09-03 15:48:24.411000 [blink.exe 12056]: RECEIVED: Packet 34, +0:05:06.509000
SIP/2.0 500 Service Unavailable
Via: SIP/2.0/UDP 192.168.0.252:59027;rport=59027;branch=z9hG4bKPjc09958e53118452ba40500c934e3ef80
To: "Jake" <sip:JakeIP@192.168.0.99>;tag=5ef23fa77034c447eed92f18b3d46d92-4312
CSeq: 2 REGISTER
Server: kamailio (3.2.2 (ppc/linux))
Content-Length: 0
Im pretty new to all this SIP stuff so im not really sure whats going on. There are no firewalls to speak of and no ports are blocked so i cant understand why this connection would not be working.
Any help or pointing in the right direction for reading would be very much appreciated.
Cheers
Re: Trouble connecting with software SIP
You should register like this:
From: "Jake" <sip:1234@192.168.0.99>;tag=ed28f4ffde994e56a83a11f36ccfacee
Where 1234 is a SIP extension declared in OXE.
smith_user
Hi tot3nkopf
I think i am doing as you said, the user is listed as basic SIP in the subscribers section of the OXO. I attached a photo of the list. I have changed the port on the SIP phone to use 5059 as opposed to the SIP standard 5060, but it seems as though this ICMP response is stopping the handshake. Im reading everything i can, but any help is appreciated.
Cheers
Jake
And the configuration of your SIP phone is..?
Return to “SIP”
