PCM r2 OXO outgoing
Claudio
PCM r2 OXO outgoing
Post by Claudio »
Hi all I have a pcm OXO a connected r.820, my problem is with outgoing calls by dialing abbreviated ARS and the call is not made, if I call it manually without ARS works well, it is possible that the provider does not accept numbering in block? any ideas?
Thanks for the help
Re: PCM r2 OXO outgoing
pcmr2
are you using hash key as end of dialing for your abreviated numebrs? pcmr2 doesnt support it
Return to “Configuration”
