Is it possible to build 2 SDP's from the same Ethernet port?
hillstream
Post by hillstream »
SDP Question.doc
I would like to know if it is possible to build 2 separate SDP's from a single customer Ethernet access port on a 7705 to a remote 7705 that will be connected to 2 separate customer devices for redundancy. If one of the remote customer devices fails then the other can support the customer over the other SDP. I have attached a drawing of what I would like to do. If this is possible I would also like to make it that only ONE of the SDP's is active at one time so as to not use double the bandwidth.
cadet
Re: Is it possible to build 2 SDP's from the same Ethernet p
Post by cadet »
Hi.
I think you need one SDP on both 7705 and access tagged port on left equipment, and two epipe to the each customer equipment on the right side.
Andrey
Return to “7705 SAR”
