PCS In Standalone Mode
corasa
Post by corasa »
Sorry for my english.
We have several PCS and two PCX Enterprise, one of them as active and the other passive.
When a PCS loses connectivity with the active PCX, PCS happens to work in standalone mode.
This usually occurs when data packets are lost due to problems with the link.
How I can make this not happen when packet loss is very low and sporadic?.
Is there a system value that can be modified for the PCS not pass quickly to work in standalone mode?
Thank you.
Here are example
The output of this command is like this:
(12)xa000012> config 0
Wed Nov 27 15:04:07 ART 2013
| 0 | 6 | App. Server|---------- | IN SERVICE | NO PCMS CODE |
| 0 | 10 | App. Server|---------- | IN SERVICE | NO PCMS CODE |
> Reference rack number: 2
> Display list of PCS :
| PCS Name | Address | State |
| laplata | 10.20.1.1 | INACTIVE |
| benavides | 10.25.1.1 | INACTIVE |
| mendoza | 10.120.1.1 | INACTIVE |
| cordoba | 10.220.1.1 | INACTIVE |
| rosario | 10.170.1.1 | INACTIVE* |
| sanjuan | 10.30.139.1 | INACTIVE |
| riogallegos | 10.240.1.1 | INACTIVE |
| neuquen | 10.150.1.1 | INACTIVE |
| demayo | 10.30.145.1 | INACTIVE |
| retiro | 10.30.1.1 | INACTIVE |
| corrientes | 10.210.1.1 | INACTIVE |
(12)xa000012> incvisu | grep 10.170.1.1 | less
28/11/13 11:37:41 000012M|---/--/-/---|=4:0428=CS->PCS: @IP 10.170.1.1 error 0 PCS domain 41
28/11/13 11:37:41 000012M|---/--/-/---|=2:0429=PCS 10.170.1.1 is activated
28/11/13 11:39:34 000012M|---/--/-/---|=4:0428=CS->PCS: @IP 10.170.1.1 error 1 PCS domain 41
28/11/13 11:39:34 000012M|---/--/-/---|=5:0430=PCS 10.170.1.1 is disabled
28/11/13 16:46:57 000012M|---/--/-/---|=4:0428=CS->PCS: @IP 10.170.1.1 error 0 PCS domain 41
28/11/13 16:46:57 000012M|---/--/-/---|=2:0429=PCS 10.170.1.1 is activated
28/11/13 16:57:00 000012M|---/--/-/---|=4:0428=CS->PCS: @IP 10.170.1.1 error 1 PCS domain 41
28/11/13 16:57:00 000012M|---/--/-/---|=5:0430=PCS 10.170.1.1 is disabled
swinstu
Re: PCS In Standalone Mode
Post by swinstu »
Did you find the solution this. Please post for everyone's sake. Thanks
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
Return to “System”
