HSL 1 and 2
torrentula
HSL 1 and 2
Post by torrentula »
Is there a difference between the HSL 1 and HSL 2? Will a HSL 1 work in the HSL 2 slot?
Thanks.
tincho.rn
Re: HSL 1 and 2
Post by tincho.rn »
Hi. For each GD you can use two HSL links to connect to two more MG (using MEX). Regardss.
torrentula
Re: HSL 1 and 2
Yes, I understand that part of it. My question is, is there a difference between the HSL 1 and HSL 2 boards. I need to buy spare parts for our existing customers and wasn't sure if I needed one of each or if the HSL 1 could be used for either slot on the GD.
The reason I question this is because Alcatel lists them as two different parts with two diffent part numbers, but at the same cost. WHY :?:
Thanks.
et
Re: HSL 1 and 2
Post by et »
HSL1 - for one link, HSL 2 - for TWO HSL links. HSL2 can be set on only GD (OXE) or CPU (OXO) for connecting two extension cabinets through MEX boards. HSL1 and HSL2 uses the same, only one position on GD/CPU. HSL1 and HSL2 are different daughter boards. I suppose, it's clear now.
L_lefante
Re: HSL 1 and 2
Post by L_lefante »
is there a way a to check if a GD/GD-3 has a HSL-1 or HSL-2 from config???
Re: HSL 1 and 2
not sure - may be "config [shelf] -d"
L_lefante
Re: HSL 1 and 2
Post by L_lefante »
Hi Vad,
It seems that there is not such information from that command.
Any other idea to check this without looking directly the hardware?
Enviado desde mi LG-D722 mediante Tapatalk
murraya
Re: HSL 1 and 2
Post by murraya »
easist thing is to see how many mex cards run off that gd.
i.e. if you have just gd shelf and no expansion cabinets then no hsl, one expansion cabinet gd will have hsl1, two epansion cabintets the gd will have hsl2.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Re: HSL 1 and 2
murraya wrote:i.e. if you have just gd shelf and no expansion cabinets then no hsl, one expansion cabinet gd will have hsl1, two epansion cabintets the gd will have hsl2.
But if you have one expansion cabinet and HSL2? F.e. during initial ordering - was supplyed HSL2 (for future expansion).
murraya
Re: HSL 1 and 2
Post by murraya »
sorry, not used to sales people thinking ahead :)
as this is only for "on stock" spares and if he has only systems with 1 expansion then an hsl1 would do the job.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Return to “Boards”
