Changing SIP gateway port
enio.eltz
Post by enio.eltz »
Hi There
On my understanding I think it is not possible.
I have an OXE R9.1_i1_605_41 with 5 SIP extensions. They exchange SIP packets with OXE on port 5060.
Is there any way of changing the port OXE listens to? For example, from 5060 to 6060?
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
Re: Changing SIP gateway port
Don't see how...it is configured on the SIP Gateway initial setting. I guess you'd have to destroy it (no clue how) and then reconfigure all.
Maybe a DB modification could do it...
enio.eltz
Post by enio.eltz »
Hi cavagnaro
Yes, I think the same. I am going to talk to ALU and check it out. Maybe they have an information. I share here if I get something.
Thanks.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
Return to “SIP”
