CPU Usage Utilization 100%
thekotaksampah
Post by thekotaksampah »
Dear All,
I have problem with 7750 SR-7 Router..
When I found IP VPRN service loopback, and then vrrp discard the packet
VRRP check failed
"Discarded VRRP packet from 10.253.68.60 because packet is looped back to itself!"
then the cpu usage raise until 100%
the contribution of CPU Usage is
IP Stack
VRRP
and Logging..
Please can you give me reason why this happen.. And The solution must I do. Thanks
BR,
Thekotaksampah
Technical Blog: ngoprek.achyarnurandi.id
mivens
Re: CPU Usage Utilization 100%
Post by mivens »
Sounds like you have a loop in your network if your own VRRP packets are being sent back to you.
You need to fix this, perhaps using a loop prevention technology such as Spanning Tree or MAC Move.
thekotaksampah
Hi. guys.. I have another problem in the same case..
lets check the log
CPU Utilization (Sample period: 1 second)
Name                                   CPU Time       CPU Usage        Capacity
                                         (uSec)                           Usage
BFD                                           0           0.00%          0.00%
BGP                                         279           0.02%          0.02%
CFLOWD                                        0           0.00%          0.00%
Cards & Ports                             8,873           0.88%          0.28%
DHCP Server                                 101           0.01%          0.01%
ICC                                      14,668           1.46%          1.48%
IGMP/MLD                                    770           0.07%          0.06%
IOM                                           0           0.00%          0.00%
IP Stack                                 16,821           1.68%          1.45%
IS-IS                                     1,845           0.18%          0.18%
ISA                                       1,109           0.11%          0.11%
LDP                                      27,901           2.79%          2.79%
Logging                                      26          ~0.00%         ~0.00%
MPLS/RSVP                                 1,844           0.18%          0.11%
MSDP                                          0           0.00%          0.00%
Management                              799,898          80.06%         78.70%
OAM                                         937           0.09%          0.06%
OSPF                                      3,289           0.32%          0.32%
PIM                                       6,153           0.61%          0.35%
RIP                                           0           0.00%          0.00%
RTM/Policies                                  0           0.00%          0.00%
Redundancy                               17,145           1.71%          1.19%
SNMP Daemon                              30,323           3.03%         75.24%
Services                                  1,890           0.18%         75.78%
Stats                                         0           0.00%          0.00%
Subscriber Mgmt                           1,121           0.11%          0.03%
System                                   63,529           6.35%          3.11%
VRRP                                        390           0.03%          0.02%
WEB Redirect                                169           0.01%          0.01%
Total                                   999,081         100.00%
   Idle                                       0           0.00%
   Usage                                999,081         100.00%
Busiest Core Utilization                999,081         100.00%
the main contribution is management.. so can you helpme why this happen.. and from where this happened?
Return to “7750 SR”
