Voice Guide Directly Access Prefix
giovanni.attolini
Post by giovanni.attolini »
It's possible create a prefix or a ghost user to play a specific voice guide directly?
Giovanni A. Attolini
oldboy
Re: Voice Guide Directly Access Prefix
Post by oldboy »
What are you trying to achieve?
giovanni.attolini
I want to create a hunt group overflow to a message.
freedom
Post by freedom »
I don't think that this is possible.
You could send incoming calls to an incoming greeting guide, but not for an overflow on a hunt group.
Do you have a voicemail system? Perhaps you can set the overflow to a virtual extension that has a direct forward to voicemail.
Then you records the message as a welcome message of the voicemail box.
giovanni.attolini
No, I don't have voice mail, only IAA.
Sent from my iPad using Tapatalk HD
Return to “Voice Guides”
