INTOF2 Trouble
Split
INTOF2 Trouble
Post by Split »
Hi all
i have trouble with INTOF2 Cards and want know if there are some maintenance commands for this board?
Oxe Release 11.0 -30-f running
I get many incidents like this:
30/01/14 18:17:54 001001M|000/05/-/---|=2:3720=C1 Access Pb INTIP3[INTOF/INT2B]Hexa C1Flag:f1,fe[Time],HostFlg:0,0,HstST:0,LINE:0,0,
30/01/14 18:18:18 001001M|000/19/-/---|=2:3720=C1 Access Pb INTIP3[INTOF/INT2B]Hexa C1Flag:f1,fe[Time],HostFlg:0,0,HstST:0,LINE:0,0,
incinfo GEA 3720 not really help ......... im a litte bit confused :(
with Release 11.0-25f i dont get this incidents but we have install the -30f patch because external Handover was not working.
Did somebody know how i can check if the INTOF2 Cards have the right binarys flashed .........i get incidents with binary download if i put the INTOF2 Cards in ....but may be i can check it like INTIP´s => readhead INTIP
Somebody a idea?
Thanks a lot
Split
Re: INTOF2 Trouble
Post by Split »
Update: with cpl_online 0 5 connect to INTOF2 Card => ?? you can see the binary which is flashed in this case ist 3.1 this are the right binary => so my problem still consist :(
Eliott
Re: INTOF2 Trouble
Post by Eliott »
It is a SW problem in r11.0
You have to wait for R&D.
As soon as fixed I let you know the solution.
azamated
Re: INTOF2 Trouble
Post by azamated »
Have the same issue
please let me know as well
tgn
Re: INTOF2 Trouble
Post by tgn »
Having a similar issue here in 2 telephone systems:
-R11.0 Patch 30f
-R10.1.1 Patch 27
in R11 the failur is like this:
26/02/14 07:44:24 000000M|000/13/-/---|=2:3720=C1 Access Pb INTIP3[INTOF/INT2B]Hexa C1Flag:f1,fe[Time],HostFlg:0,0,HstST:1,LINE:0,0,
in R10.1.1 Patch 27 the incident is a little bit different:
09/04/14 10:18:32 000001M|000/08/-/---|=2:3720=C1 Access Pb INTIP3[INTOF/INT2B]Hexa C1Flag:f1,fe[Time],HostFlg:d,0,HstST:a,LINE:2,84
both systems have
duplicated cpu7step2 with io2n
a double intof connection to the remote shelf.
a voicemail system (vpu5/vpm35)
intip boards in the remote shelf.
regards...
Eliott
Re: INTOF2 Trouble
Post by Eliott »
Problem is solved with firmware bnvintof (NVTOF2) 3.2 09Apr14_12h22
(Officially solved from R11.0 k1.400.33.a)
bnvintof.zip
Split
Re: INTOF2 Trouble
Post by Split »
Thanks for the information eliott did somebody know the impact for the system .....last week we did a upgrade to r11.0.1 and the binary still 3.1 ...if there no impact i wait for a official patch ...
Eliott
Re: INTOF2 Trouble
Post by Eliott »
No impact. You can use the same binary in R10.1.1
stancu_adi
Re: INTOF2 Trouble
Post by stancu_adi »
There is any impact for the users?
I'm opening an eSR but want to know if till i will have an answer to try to update or not the binary provided by Elliot.
Thanks,
Adrian
Return to “Boards”
